Lason's 240Z
Old Apr 7, 2008 | 08:10 PM
sick240's Avatar
alright here are a few, the car is now sanded down to metal and looking for a good bodyguy. time for paint.
Attached Thumbnails Lason's 240Z-000_0038.jpg   Lason's 240Z-000_0040.jpg   Lason's 240Z-tubs.jpg   Lason's 240Z-000_0041.jpg
Old Apr 7, 2008 | 09:12 PM
Lason's Avatar
Im really digging that. I almost went with ladder bars but I liked the fact that I could shorten the 4 link down to where I need it. Hurt my adjustability but I should be ok.
Old Apr 9, 2008 | 07:13 PM
sick240's Avatar
well let me know next time you go out or we could even cruise out to the track. looks like it will be next month before paint so might as well take the car out till then.
Old Apr 9, 2008 | 07:26 PM
jw33's Avatar
May 18th Texas Raceway, Kennadale....
Old Apr 22, 2008 | 12:59 PM
Lason's Avatar
Well I just got the damn thing going and had some fun at the track with it (7.60@92) and its about to go back under the knife. Here are the pics of the new toys for it...........
I also have a Megasquirt setup on the kitchen table being assembled as we speak. Should be back up and running in a couple weeks.
Old Apr 22, 2008 | 03:39 PM
jw33's Avatar
you going to try and get it going with the snail before the dfw cruise?
Old Apr 22, 2008 | 04:40 PM
Lason's Avatar
Im gonna try! Starting on the exhaust this week. Got all the parts I need minus a set of injectors,throttle body, elbow and fuel pump/reg. So money may hold me back. Not to mention, when its done Im going to have to get it over to gearheads for a tune. Alot to do before 19th
Old Apr 22, 2008 | 04:51 PM
Sabre002's Avatar
yes this is what I'm trying to get my buddy to do with his 92 coupe 240Z.
Old Apr 22, 2008 | 05:17 PM
Lason's Avatar
92 coupe 240Z??
Old Apr 22, 2008 | 07:47 PM
gimmie11s's Avatar
your car is sick.
what did you use to adapt the lsx to the powerglide? hughes flex and coupler?
what are you initial thoughts on the msd 6010??
again.. sweet car!
Old Apr 23, 2008 | 10:14 AM
Lason's Avatar
The tranny physically bolted to the motor except for one bolt not drilled out on the LS1's, but as far as the converter I have a custom built converter in it that I got through Gilbert at Ace transmission's, a sponsor on here. A buddy had it built then sold his project so I picked it up instead. Basically its just a 350/400 converter with a crank snout extension welded onto it. Performance Tourqe Converters in Kennedale Tx built it.
The ignition box is great so far. I have heard they start breaking up at 7k rpms so Im going to have to keep an eye on that if I go that high. At that point I may just upgrade the megasquirt to take over the ignition.
Thanks for the compliments.
Old Apr 23, 2008 | 10:11 PM
  #32
sciff5's Avatar
You have any more detailed pics of the headers? I'de like to see how they fit. I have an LS1/rx7 and I am having issues making the longtubes I'm using fit.
Thanks man
Old Apr 23, 2008 | 10:49 PM
  #33
Lason's Avatar
I got blockhugger on it now and will be building the turbo headers this weekend more than likely. The ones on it now are Sanderson 1 3/4" blockhuggers and they fit very good.
Old Apr 24, 2008 | 12:11 PM
  #34
sciff5's Avatar
now by any chance would you remember the part number of the lower radiator hose you used?
Old Apr 24, 2008 | 02:42 PM
  #35
Reckless's Avatar
Super Moderator
Nice build....lots of work there!
Old Apr 24, 2008 | 02:59 PM
  #36
Lason's Avatar
Lower hose is a mix of two hoses with a coupler. It was a pain and the only suggestion I have is walk the isle at your parts store and see what will work.
Old May 2, 2008 | 05:55 PM
  #37
Lason's Avatar
Couple updated pics of the turbo build.
Radiator tilted foward to make room for the hair dryer
AMS-1000 Boost controller mounted and wired up
Removed water pump and will use a remote pump for more room for the passenger side header. Driver side header done. Excuse the welds, Im still learning how to mig tube. Flat surfaces are a cake walk compared to this stuff.
Old May 9, 2008 | 09:02 AM
  #38
Lason's Avatar
Damn this thread is a little outdated. Need some new pics. Built the other header, crossover, brace for the turbo and got my wastegate mounted. Leaving now to get the 5" bends for the downpipe and after that the turbo should be done minus the short intake pipe so thats no biggie.
Old May 9, 2008 | 09:27 AM
  #39
ghettocruiser's Avatar
Ummm.... NIIIIIIIICCCCCCEEEEEEEE....
That is friggin awesome! I love those Z's and the direction you are going with it is fantastic! Good work with the fab and design too!
Keep the updates comin!
J.
Old May 9, 2008 | 09:28 AM
  #40
FadedFD's Avatar
That ride is going to be nuts with that snail set up. Looking real good
