Take a look at this alternator..
If need be I can take a picture or 2 tomorrow after work of my 3.4's alternator as it sits on top and is easily viewable, and I can trace that wire to the main fuse block to verify my assumption.
Heres a pic of mine.....
Painless makes a nice plug with directions and the resistor included....
What ever you do dont feed 12v straight to the alt.Ideally if yours is a 99+ ls1, hook the wire to the PCM. You can look up the pin number on the FAQ stickies.
Otherwise have a resistor or BATT light inline between the 12V source and the alt
read this as well
https://ls1tech.com/forums/showthrea...led+alternator
