another new conversion, no spark
Old Mar 31, 2008 | 09:18 PM
los bastardos's Avatar
Default another new conversion, no spark
and I'm out of ideas.
Here's what i've done:
car cranks, but doesn't start. No backfires, no puffs, just a smell of fuel in the air
tried:
unplugging the MAF
jumped all 8 injectors to make sure they clicked, I also pulled the rail and put paper towels under each to make sure it squirted some fuel when the engine turned over
fuel at the rail is 58PSI, solid
checked +12v at the pinks while cranking
checked +12v constant to the oranges, when cranking
the fuel pump is run directly to the battery so it has power during crank
replaced CPK
tested +12 and ground at CPK, wiring is all in good condition
tested +12 constant and ground to ECU
double checked the vac lines, no leaks
checked ground and +12 to coils
the CPS is plugged in
confirmed no spark with a plug
new plug wires
I put a cam in the engine while it was out, I lined up the dots and cranked the engine around like 20 times to make sure it stayed in and every other rotation it came back around and lined up so I think that's OK, it's a small cam and I have comp 7.4" rods in it, I guess the compression check will tell me if the valvetrain is OK. I doubt it's anything to do with my problem.
anything else to look at? I'm quickly running out of ideas. All I can think is it's time to ship the ECM off to someone to try on their car, but I don't know.
VATS was supposed to have been eliminated but I have no way to know it got done.
Old Mar 31, 2008 | 10:21 PM
ssduane's Avatar
I'm still working mine. DO you have spark when cranking, is the plug sparking? Pull out and ground on exh manifold to see. Is the wiring done right? Is left bank inj wire on the right bank and vice versus? Drivers side should be 1-3-5-7, I think.
Just a thought, or two.
Old Mar 31, 2008 | 11:09 PM
No, I get no spark at all.
Old Apr 1, 2008 | 07:07 AM
sho-me speed's Avatar
Closed ex-Sponsor Account
Just because you have voltage at the CPS or CKS doesn't mean they are any good. Had a CPS go out and it did the same thing yours is. I would fet a new CPS before i sent my computer off.
Old Apr 1, 2008 | 07:59 AM
I'll order a new one and give it a shot
thanks!
Old Apr 1, 2008 | 08:56 AM
Rodder's Avatar
How are you checking spark? With a spark plug laying on the valve cover, or with a timing light? The timing light won't fire if your plugs are fouled. And your plugs are more than likely fouled by now if you've been cranking it over a bunch with no spark. Pull your fuel pump fuse until you figure out the spark problem. Replace the spark plugs, too.
Old Apr 1, 2008 | 09:52 AM
exodus's Avatar
sounds relly stupid, but I had the same issue a while back, and it turned out to be a shorted o2 sensor. the back of the sensor hit the frame upon install of the exhaust, and was shorting. This may or may not apply, but just throwing it out there as an option. I would have never found it without john's help from speartech.
Old Apr 1, 2008 | 11:27 AM
with a plug, I haven't cranked it that much and they look good, they're brand new plugs.
I guess it could be bad plugs :dunno:
Old Apr 1, 2008 | 11:29 AM
you never know but I don't have any o2 sensors plugged in and the wiring looks good.
Old Apr 1, 2008 | 02:00 PM
andrew69_04's Avatar
sounds like a bad sensor if all your power wires and grounds are correct. did you double check the 3 grounds on the back of the driver side head?
Old Apr 1, 2008 | 02:21 PM
I'm sorry, yes I did check them. I grounded them with the intake bolts under the assumption that those, connected to the heads, would be a good ground. I traced it with my DMM to be safe and it seemed to be a pretty good ground.
I ordered a cam pos. sensor, maybe mine got jacked. I don't know if a bum MAF will prevent spark, I figured it wouldn't but I dunno.
Sure hate to pull that intake again just for one dumb sensor.
Old Apr 2, 2008 | 07:25 AM
exodus's Avatar
move ground wires from the intake bolt to a bolt on the backside of the head
Old Apr 2, 2008 | 12:14 PM
I'll try her, thanks! Or to test I'll just jumper it over to the - term.
Old Apr 4, 2008 | 08:17 PM
new cam sensor did the trick, thanks guys
Old Apr 5, 2008 | 01:14 PM
exodus's Avatar
glad to hear you got it fixed
