Gas tank questions
What's the white barbed connector go to? And then off the purge thingy, there is another "fuel line". Off the pickup I obviously have a feed and return line, but I don't know what this other line goes to.
As far as the white one on the center of the tank i'm sure it has something to do with the vapors also.
I believe you can cap both off and just make sure you run a vented gascap.
The one on the sending unit is for fuel vapors from the intake manifold,
The one in the middle of the tank is where the tank vapors goto the canister for recovery.
