1999-2000 LQ4 6.0 Engine Fitment 4l60E
Old 06-15-2014, 10:52 AM
ParkerTPIz's Avatar
Are there any tcs that aren't as thick?
Originally Posted by lowerthanyou00
It's not a matter of bolts lining up, it's the crank is too long making its pushing the converter further into the trans. If you try to bolt it up you'll bust the bellhousing. Only way is to put in a newer shorter crank.
Old 06-15-2014, 02:35 PM
lowerthanyou00's Avatar
Read post #13
Old 06-16-2014, 11:22 AM
ParkerTPIz's Avatar
Read post #13
Thanks, well thats a bummer...hate to shell out another 400bux.
So i need to either buy one of those tcs, swap the crank, or get an 80e? Are there any other alternatives?
Old 06-16-2014, 12:50 PM
ParkerTPIz's Avatar
O and I have a call in to Art, probably end up going that route. He's been very helpful so far.
Old 06-16-2014, 10:10 PM
Cool, good luck with the build. Definitely top shelf shop.
Old 06-24-2014, 10:43 AM
ParkerTPIz's Avatar
Talked to Art, $408 shipped to my house. Which isnt bad but...
Has anyone tried to use a different stock converter? Like an Lt1 or Gen2 SBC converter. Theres gotta be a less expensive fix.
Any one have any side by side comparrisons with TCs and fitment on the 99' lq4s with ls1 4l60es?
Old 06-27-2014, 11:17 AM
ParkerTPIz's Avatar
Anybody tried this? Success with a gen1 or 2 sbc torque converter??
Old 07-07-2015, 07:41 PM
Ls1000's Avatar
Default Same issue
Ok i have an lq4 off an 07 chevy 2500 and im having the same problem when i start bolting the trans to the block the flexplate wont spin not the converter nor the crank pulley... By the way i have a 4l60e ls1 trans. Does my crank have a spacer in the back or is it just like that, long???
Old 07-07-2015, 09:57 PM
Pocket's Avatar
LQ4's always had a 4L80E for autos so yes it will have the flat flexplate with the adapter. Lucky for you the 07 was removable, so unbolt the flexplate and the adapter should come off with it. Bolt your 4L60E dished flex plate directly to the crank using the shorter style bolts
Quick Reply: 1999-2000 LQ4 6.0 Engine Fitment 4l60E
