Autometer Guage Questions, for LS1 into SN95
I will be running the autometer 10008 replacement instrument cluster seen here: http://www.egauges.com/vdo_acce.asp?...f=Auto%20Meter
So my plan is
3 3/8" Tach
3 3/8" Speedo
2 2/16" Volts
2 2/16" Oil Pressure
2 2/16" Water Temp
2 2/16" Fuel Level
Now my questions are what guages I need (what ohm sensors etc).
Im going with Ultra-lite II guages.
Which speedo do I need? Part number: ATM-4988 or ATM-4989? Link to them: http://www.egauges.com/vdo_mult3.asp...ite_II&Units=E
Which Fuel Level Guage? Part number:ATM-4913, ATM-4915, or ATM-4916?
Will be using the Factory ford V6 tank with a Walbro 255lph installed.
Thanks for them help, want to order these asap.
So my plan is
3 3/8" Tach
3 3/8" Speedo
2 2/16" Volts
2 2/16" Water Temp
2 2/16" Fuel Level
So my plan is
3 3/8" Tach
3 3/8" Speedo
2 2/16" Volts
2 2/16" Water Temp
2 2/16" Fuel Level
So my plan is
3 3/8" Tach
3 3/8" Speedo
2 2/16" Volts
2 2/16" Water Temp
2 2/16" Fuel Level
I used a fuel level sending unit from an '86 GT mustang (73 ohms Empty/ 10 ohms Full) in my fuel tank with 4915 style gauge and it works perfect. My car is a '91, but I beleive the fuel tank sending units will interchange. But the sending unit is around $80-$90 and I see that they have a programable gauge for only $125 so that would be less expensive than buying the regular 4915 gauge + a new sending unit....
BTW I love the way the Ultra Light II's look at night. I have the Carbon Fiber gauges and they look like **** at night. I ordered some LED's to hopefully help, but I still don't think they will look that great.
My gauges are Ultra lites IIs and the coolant temp sensor doesnt fit haha. It's a standard thread whereas the coolant temp sensor in the LS1 is an M12x1.5 thread pattern I'm still trying to find where to get an adapter. I heard you could use a die and rethread the bushing that came with it but i couldnt get it to work.
