drive by wire inop???
Old Apr 17, 2008 | 11:03 PM
orangefun's Avatar
Default drive by wire inop???
ok I got my 5.3 started, but the when i push the gas pedal nothing happends, i have the tac module and the pedal all hooked up, is it true that sometime you have to let the vehicle idle for 8-10 min. for it to learn it self agian after a tune??? any ideas????
Old Apr 18, 2008 | 07:03 AM
01WS6/tamu's Avatar
You need to run a scan tool on it and see what codes it has. Since it's inoperative it has codes stored. Anything less and you will we wasting your time. It should work immediately provided the tps' are within range, and the tac module has power and communications with the pcm.
Old Apr 18, 2008 | 08:33 AM
76LQ9TA's Avatar
Who programmed your computer? When I had my computer flashed the first time the programmer assumed I was going to use a cable throttlebody. It would start but would only idle. I would check this as well as trying to pull codes.
Old Apr 18, 2008 | 09:55 AM
orangefun's Avatar
I will try and use my friends snap on scanner, I will get back to you guys today
Old Apr 18, 2008 | 12:40 PM
Stu Cool's Avatar
Just FYI, your throttle should work with the key on without the engine running. Do you see any movement at all when you move the pedal?
Pat
Old Apr 18, 2008 | 12:45 PM
orangefun's Avatar
no and I just got the code p0122, bad tps??? i will be back going to check the 5 volt referance
Old Apr 18, 2008 | 12:55 PM
orangefun's Avatar
5 volt ref is good, what next??
Old Dec 16, 2008 | 09:42 PM
Ford_Assassin's Avatar
Another run at the top....
I am having the exact same issues with my 5.3 swap.
Old Dec 17, 2008 | 12:50 AM
ls1_chevelle's Avatar
when you turn your key on but not starting the engine, do you hear your throttle body reset itself? Like can you hear the gear drive and motor move slightly?
Old Dec 17, 2008 | 09:18 AM
All I can hear is my my Walbro inline fuel pump when I turn the key to the 'on' position.
Would this be something I could see if I was looking at the tb blade and had someone else turn the key on?
Thanks!!
Old Dec 17, 2008 | 09:39 AM
Okay, I unplugged the fuel pump and had my wife put the key in the 'on' position at least 10 l times while I had my eyes and ears focused on the TB..... nothing.
No movement, no sounds.
So is my throttle body dead?
Thanks!!
Old Dec 17, 2008 | 10:20 AM
A local friend of mine told me his stock 2005 Tahoe did the exact same thing when his oil pressure sender went out.
The funny part about that is I am not running my sensor because I have a Auto Meter manual oil pressure gauge in its place.
Could this be my issue?
Old Dec 17, 2008 | 11:49 AM
BusDriver's Avatar
Anything's possible. Do you have the sensor to put in temporarily and try? If so, try it. Can't hurt anything.
Old Dec 17, 2008 | 12:29 PM
I have my oil pressure sensor pulled out and do not have this issue.
When my TB was a dud, it would re-set the blade, but would not operate. If you can get your hands on another one to test, give it a go.
