Carbed intake?
Old Apr 19, 2008 | 09:23 AM
deuce4935's Avatar
Question Carbed intake?
Which is better, GMPP or Edelbrock?
Old Apr 19, 2008 | 09:57 AM
TJ's Avatar
TJ
GM for quality and hood clearance. its amazing the difference in the ports and finished work.
if you are for all out hp/cost factor, then get the victor jr and dont look back.
i have ran all three.
GM
edelbrock dual plane
edelbrock vic jr.
they have a super victor out now as well, if you are making 600+hp.
Old Apr 19, 2008 | 10:35 AM
deuce4935's Avatar
Thanx for the reply. I came across a brand new GMPP for little or nothing and I'm just trying to figure out if its the one to run. I dont plan on racing, it's just going to be a street cruiser, and I'm hoping to make somewhere between 400-450hp with the Z06 cam, LS2 heads, 1.8 rr, and some port matching.
Old Apr 19, 2008 | 06:55 PM
Ionize's Avatar
GMPP here, great on the street with 243 Z06 cnc heads, G5X2 cam with a 750 mighty demon in my T-Bucket
Old Apr 19, 2008 | 08:45 PM
garys 68's Avatar
TJ
How much differenve was there between the dual plane and the single pane manifold.
I bought a 6.0 and was considering the GMPP carb intake with injectors, but didn't want to lose tthe torque of the dual plane at hiway cruising rpm, around 2000rpm.
GM
edelbrock vic jr.
Old Apr 20, 2008 | 06:44 AM
forcd ind's Avatar
is there a height diff between the gm and edl. single plane?-i have the edel., and with the carb hat on the blowthru, if i could get it down 1/2", i could use my stock ss hood (69 chevelle)
Old Apr 20, 2008 | 06:54 AM
garys 68's Avatar
I did a search on here and found a couple posts about the Edelbrock being taller. Thats why I'm going with the GMPP.
Old Apr 20, 2008 | 10:34 AM
TJ's Avatar
TJ
thats the 1st time ive ever seen the whole engine painted, and you pulled it off.
that looks really nice! thanks for not painting the intake bolts, that would have ruinded it.
nice job!
Old Apr 20, 2008 | 10:37 AM
TJ's Avatar
TJ
Originally Posted by garys 68
TJ
i dont remember the exact height i measured.
gm intake, 1" spacer, and a 3" drop base carb, cleared my hood fine.
vic jr, spacer, air cleaner wont fit. without the spacer a filter will fit, but i cant put a stud on it.
as in street manners, the GM all the way. its way more torqey feeling down low. that really doesnt matter to me, i like the track times. picked up almost a 10th, and about .6mph. i ported it and picked up some more.
Old Apr 20, 2008 | 10:42 AM
garys 68's Avatar
Does the cathedral port (LS1 @ 2) GMPP manifold come with thr injector holes drilled?
If so, does GMPP make a fuel rail for it?
Old Apr 20, 2008 | 10:48 AM
TJ's Avatar
TJ
everything ive seen, no. check with wagner. they may be able to sell you a unit setup for efi.
the intake is cast with an area to be drilled, so its not like youd be guessing at it.
if you knew the specs and had the tools, you could drill the proper holes.
Old Apr 20, 2008 | 11:11 AM
garys 68's Avatar
If the efi bosses only needed a vertical hole, I could probably drill them and buy a universal rail and drill that to match. But from what I've seen, they're angled on all the LS motors.
It might just be easier to go with the Victor JR and edelbrock rail.
Old May 2, 2008 | 09:14 PM
neckspeed's Avatar
Default gmpp intake
if any one knows where to get the gmpp intake drille for fuel injectors please let me know. i want someone that has done them before and knows what there doing. any help much appr. thanks
Old May 2, 2008 | 10:11 PM
TJ's Avatar
TJ
you can try and pm bc56f100 on this board. he got a victor junior done and it looks sweet.
