LS2 KOUKI BUILD AKA "HEART OF A GOAT" 56k beware**
#81
he said he had a complete pull out from a 06 gto so yeah he has an m12. i have an m12 in my notchback with f body shifter. you just have to change the shifter cup that the ball of the shifter sits in. he also has pics of that....
#82
Very nice, very clean! I bet that thing would do even better with a different muffler, the outlet hole inside that tip looks kinda small, I'm sure it was designed for an engine with much less displacement. SWEET car though!
#84
Damn ruthless you been at this a while hope everything works out. When you get it done you need to come down and to a photoshoot with LS14 (Chris) and I.
You and chris have identical cars and I should be done with my third LSx Nissan. You should look into attending Import Alliance in Nashville next year.
http://videos.streetfire.net/video/I...008_181071.htm
www.wakeperformance.com if im not mistaken but its a mustang cobra shifter ****
thanx man...well you know like i know koukis are hard to come by nowadays!!!!
#87
the muffler is 3.74" diameter its an apex-i gt spec the biggest exhaust the japs make pretty much!! in conjunction with 3" kooks y-pipes. I loud how the exhaust sounds (to me sounds more like a mustang) I would never but dual exhaust on this kinda of car because it would look gay. I will post a exhaust note video soon!!!
As you can tell I'm more old school.. I think Duals if done right would look sick.. But again you would loose the stealth status..
Of course the sound of that V-8 is a dead give-away but that wouldnt be revealed until you blast past the clown thinking you have four cylinders less.
Awesome build..
#88
all gto's come with m12. they have zo6 gearing and different sycnhros then f bodies. thy basically are the same as a zo6 tranny but configured like an f body tranny. look unde the hood of a gto at the placard on the frame rail behind the driverside headlight and there a tag that says transmission: m12
#90
thanx
I do like the stealth look of the exhaust.. looks more like a ricer.. complete with "coffee can" exhaust
Awesome build..
Awesome build..
thank you
#94
I understand my tranny is broke.. It happened right after I installed a plate kit. Good luck with it! keep us posted
#99
Okay after driving this car around for about 3 months I realized that my clutch was **** from day one and my dumb *** should have changed it during the swap. So xmas came a little early this year in the tune of a new clutch from SNL Perfomance Its a Monster clutch Stage 3. Also I installed a J30 vlsd to stop the one wheel madness.
28lbs flywheel
On my drive home I quickly realized that I havent even began to understand the capabilties of this motor and the power it holds....This clutch GRABS like a *********er too!!! The diff is what it is....locks up both wheels on launchs & gets the car slide'n for some fun like I want, and has a 3.91 gear. Over time a vlsd will be no match for this motor.
Thanx to my boys at TARMAC Motorsports for the help for this hella job yesterday
Damien getting his hands dirty!!
28lbs flywheel
