A-Body Guys, Enter:
Old Apr 23, 2008 | 01:15 PM
91parkave's Avatar
Moderator
well i dont know about the elky's and a-body gas tank similarities but heres some pics of my setup, used the 95' impala gas tank
Old Apr 23, 2008 | 02:58 PM
bczee's Avatar
I got the same pictures of my setup too.. The tank will work on most A-Body and is a cheap solution to the Aftermarket custom built tanks.
Racetronix does make a nice wiring and Walbro pump kit that can be used.
The only con's are that the Fuel Sender sits really high and you have cut into the Truck Floor to get the tank to sit up as high as you can get and build a access cover (not a bad think, My pump had problems and I was able to use the access cover to get to the sender without taking the tank down). It also does hang a bit lower in the rear section, but it is nothing that has given me any problems with.
I did have to trim the frame a 1/4" on each side for about 9".
