Why the !$&@ is thing blowing vette filter/regs????
1.,The distance between the pump and filter is only a couple of inches.Is it too close.
2.,The return line on the tank is smaller than 5/16.Is it causing too much back pressure?
I would have to say both are a possibility, how much smaller is the returns line?
A 5/16 line has .076 square inch area to return pressure, a 1/4 line has .049 sq/in and a 3/16 has .027 sq/in, so you can see that going froma 5/16 to a 3/16 is about a 66 percent reduction, which can create backpressure.
Andrew
the filter end with two lines is the inlet/return, the center line is the return and the outer line is the feed. i had the lines off mine for some reason and i got them switched going back together, it did not run but did not blow up either.
