quick disconnect size on LS1 fuel rail
Old Apr 28, 2008 | 04:56 PM
IHeartTurbo's Avatar
Default quick disconnect size on LS1 fuel rail
I'm ordering my fuel fittings/lines right now and I need to know what size the quick disconnect is on the fuel rail of an 02 f-body LS1.
Old Apr 28, 2008 | 05:38 PM
Project GatTagO's Avatar
3/8"
Andrew
Old Apr 28, 2008 | 06:25 PM
Thought so.
Where is everyone getting they're quick disconnect to AN adapters? I have quick disconnect adapters that I can put regular rubber fuel line over but I'd rather go with AN line.
Old Apr 28, 2008 | 06:34 PM
lt4malibu's Avatar
russel makes them.
RUSSELL PUSH-ON EFI FITTINGS (FOR OEM HARD LINES)
DESCRIPTION RED/BLUE BLACK
-6 AN to 3/8" hard tube adapters 640850 640853
-6 AN to 5/16" hard tube adapters 640860 640863
* Fits LT1, LT4, and LS1 (pressure side).
http://www.russellperformance.com/mc...fit/fuel.shtml
towards the bottom of the page...
Old Apr 28, 2008 | 08:51 PM
Rodder's Avatar
I'm using the Russell quick connect fittings, but I don't like 'em--they don't fit very well. I'm going to replace mine with compression/AN fittings eventually.
Old Apr 30, 2008 | 11:23 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
I have them in stock (even though my website says I do not)
http://carshop.carshopinc.com/produc...d/91200/640850
Old Apr 30, 2008 | 11:53 AM
bczee's Avatar
I was using the Russell Q/D.. but got rid of it in favor of brazing on a AN -6 fitting right on to the Fuel rail.. that way I know I have a good seal and doesn't stick out as far.. and for most of the people, how offen do you really need to disconnect the fuel line ?
Old Apr 30, 2008 | 12:34 PM
monger's Avatar
advance and autozone have the female quick disconnect with a male barb for normal fuel line, 3/8 and 5/16....look in the "help" section for gm/ford/chrysler quick disconnects.
Old May 1, 2008 | 09:39 AM
Already have a set of those, I'd rather run AN line though.
