GM part number....What is this?????
Old Apr 30, 2008 | 07:33 PM
garys 68's Avatar
Default GM part number....What is this?????
I've got a 2002 LQ9 wiring harness. There's a part with part number is 12450016. It's obviously damaged.
What is this???????????????????
Old Apr 30, 2008 | 08:08 PM
Rodder's Avatar
Generally a picture would help a lot...
rockauto's search says it's an ACDelco D2263C park/neutral switch.
Old Apr 30, 2008 | 08:09 PM
LS1MCSS's Avatar
That's been replaced by this "GM PART # 24229422 CATEGORY: Transmission Saftey/Start Warning" I got this from SDPC, but I use Rockauto a lot too.
Old Apr 30, 2008 | 08:16 PM
garys 68's Avatar
Normally. I would agree, but I had to put pieces together to get that number. lol
I was thining it was part of the DBW system.
Old May 1, 2008 | 06:01 AM
garys 68's Avatar
So what does it do? Is this where I wire in a neutral safety switch?
Old May 1, 2008 | 07:25 AM
69LT1Bird's Avatar
12450016 is replaced by the 24229422 like stated above. It is the Park/Neutral Position and Backup Lamp Switch. It does what is says, it sends a signal to the PCM as to which gear the vehicle is in so you can start the engine and also sends a signal to the backup lamps.
Old May 1, 2008 | 07:45 AM
76LQ9TA's Avatar
Is this the part you are looking at? I used the escalade wiring to operate my back up lights. There is a wire on the fuse block. When the part in the picture is in reverse, it supplies voltage to my back up lights. The linkage on my 81 that connects from the trans to the steering column wouldn't fit with my transmission. I unhooked the linkage and left the steering column in the park position. I ran the wires for the reverse lights to the escalade fuse block. This part will be your new nuetral start switch.
Old May 1, 2008 | 09:57 AM
garys 68's Avatar
That's the part!
I got the wiring diagram and now I know where to hook up my reverse lights.
I'm going with a manual trans, and there's no provision for a neutral safety switch on my 68, so I'll just be bypassing that.
