4" cutout on a third gen?
Old Apr 30, 2008 | 02:08 PM
firechicken76's Avatar
Default 4" cutout on a third gen?
ok, i just got some hawks lt's with 3" collectors, i want to run them into a 3" y pipe that merges into a 4" tube, then into a 4" cutout, then go into the regular exhaust 3". ive got a sphon crossmember now, but i have a drews crossmember (two humps). will if fit or will i have major clearance issues? anyone else done this?
Old Apr 30, 2008 | 02:49 PM
91sbcamaro's Avatar
I dont think your going to see any more benefit from a 4" cutout then with a 3". I have mine setup with a 2 3/4" y pipe into a 3" pipe going to my muffler and I have drews t-member. Your going to have a really low point where your 3" y pipe merges underneath the car to 4".
Old May 1, 2008 | 07:10 AM
ghettocruiser's Avatar
A 3" y-pipe is gonig to be tight... Its certainly doable. What mods are you donig to the motor where you think you need 3" y-pipe? Also...are you planning on getting the headers re-worked to 3" collectors?
There isnt much reason to want to go from 2.5" collectors, to 3" y-pipe, to a 4" merge just to run a 4" cut out, then back into a 3" exhaust. You are better off just running a nice 3" exhaust all the way back. It will flow plenty good if you build it well. Im running 2.5" collectors, to a custom 2.5" y-pipe, to a 3" merge...to a 3" cat back. But my system flows well so the sizing is plenty.
however to answer your question...there is room for a 4" cut out under the passenger seat area. There is a nice spot for a cut out back there. Still gonna be super tight if you are using 3" and 4" piping though...
J.
Old May 1, 2008 | 08:09 AM
my headers have 3" collectors not 2.5. mods include patriot stage 2 heads, 230 ish cam, fast 90, NW 90mm tb, and of coarse the headers...
J.
