how to modify the shift lever on a 4l60e for a ford shifter
Old May 16, 2008 | 08:00 PM
adam`'s Avatar
Default how to modify the shift lever on a 4l60e for a ford shifter
anyone have suggestions on how to use the stock shifter with the 4l60e tranny? i have a 94 mustang with a bolt on shifter cable. the 4l60e has a ball socket on the shift arm.
the tranny currently in the car had the ball cut off and welded a nut. i didnt like the outcome to much so what are you guys doing? i dont like cheese so whats a cleaner way in doing this?
Old May 18, 2008 | 11:30 AM
adam`'s Avatar
bump.
Old May 18, 2008 | 12:15 PM
lt4malibu's Avatar
cut the ball off and drill a hole?
Old May 18, 2008 | 12:29 PM
linegtdt52's Avatar
yeah that or hammer the underside
Old May 19, 2008 | 11:55 AM
00SilverWS6's Avatar
I was thinking grind the ball off my stock sn95 shifter, and grind the ball off the 4l60e arm, drill a hole in each. Then just a piece of metal between the 2 with slotted holes in each end for adjustment, with bolts/nuts to hold in place.
But it still needs to be able to pivot where the bolts go in, so maybe a bearing on teh backside or somethign IDK.
Old May 20, 2008 | 10:39 AM
adam`'s Avatar
thanks for the suggestions and options.
