My 62 Impala Project
Old Mar 21, 2010 | 06:50 PM
  #121
redz88's Avatar
Originally Posted by poolado63
They mount C5 or C6 corvette brakes. I have 2008 Z51 setup for mine.
What size booster do you have running the set up?
Old Mar 21, 2010 | 07:36 PM
  #122
poolado63's Avatar
No booster yet, still mocking up. Planning on using vette master cylinder. Heres a "before" pic of my impala and my big brakes.
Attached Thumbnails My 62 Impala Project-cars-014.jpg   My 62 Impala Project-cars-006.jpg
Old Mar 22, 2010 | 10:42 AM
  #123
redz88's Avatar
Let me know when you have these things on or at least mocked up. Definitely will look nice
Old Mar 24, 2010 | 09:43 AM
  #124
62pala's Avatar
what transmission lines did u use? Is that the stock radiator? Also, what did you do to use your 605 power steering?
Old Mar 24, 2010 | 04:42 PM
  #125
BgBoost1's Avatar
Great Project....I love the look of the 62!!!!!!!
Old Apr 7, 2010 | 08:23 AM
  #126
Mr Lavish's Avatar
Hey what rearend housing are you useing? I wonder if i rebuild the factory rearend will that ls2 motor have to much power and break.
Old Apr 7, 2010 | 12:58 PM
  #127
Brads454's Avatar
Sorry I've been MIA for awhile.
We aren't using transmission lines, we're currently running a T-56.
Stock radiator so far, yes.
The 605 box is from CPP. We had to shim it all up etc, but it fits nice.
We're running a Moser 9 inch rear end, 3.90 gears and a Tru-Trac posi unit. Not sure if the stocker will hold up, depends what you're looking to do. I used the 9" because I had most all the parts laying around other than axles and a housing.
Old Apr 7, 2010 | 08:30 PM
  #128
E.rodz's Avatar
nice build on the car so far. had the same prob. with the headers on my 63 ended up using the stock camaro manifolds the worked just fine. the x frame just blows in this way and many more ways. had to ad a perimeter frame on mine to stiffen it up a bit.trying to figure out how to start up a trread and resize picts.have more build picts on my website if this will help.
www.erodzcustoms.com
hope to se you on the power tour with it.
Old Apr 20, 2010 | 09:33 AM
  #129
redz88's Avatar
Originally Posted by Brads454
What year camaro rims were these?
Old Apr 20, 2010 | 06:06 PM
  #130
Brads454's Avatar
1991 and 1992 Camaro wheels.
Old Jun 15, 2010 | 09:12 AM
  #131
V8TV's Avatar
Great project! We're in the midst of a '59 Biscayne LS1 6 Speed project ourselves. Thanks for posting your trials here, the info will save many people lots of time in trial and error.
Old Jun 15, 2010 | 09:39 AM
  #132
V8TV's Avatar
BTW, MagnaFlow just finished the exhaust system that exists behind the rear wheels for '58 - '59 cars, I believe it fits up to '62 as well.
Old Jun 28, 2010 | 08:04 PM
  #133
Brads454's Avatar
Thanks!
I'll have to look into the kit, our exhaust guy tried a bunch of different ways to get it to work but no luck with the 9" in there.
Old Jun 28, 2010 | 08:11 PM
  #134
V8TV's Avatar
Here's the info right from a MagnaFlow rep on the system, we're all hoping it fits as described!
http://v8tvshow.com/content/view/892/1/
Old Oct 29, 2010 | 06:43 PM
  #135
Brads454's Avatar
Here are some shots I took today.
The wiring is all done, the new radiator setup is in, pretty much there other than the interior and some misc stuff.
Old Oct 30, 2010 | 05:50 AM
  #136
Stormed_Norm's Avatar
Damn ,sure loks sharp. Why did you have to shim the 605 box? I have one in my 62 Biscayne and it fit pretty good. My problem was witth the rad to steering box. The rib on the steering box hit the rad so I had to grind it down abit to give me a 1/4 " clearance between the two.
Old Oct 30, 2010 | 12:31 PM
  #137
Jimbo1367's Avatar
Brads454
Wow. Thats a sweet looking ride. I love the way the engine compartment looks.
Old Oct 30, 2010 | 10:21 PM
  #138
cdumi96's Avatar
sweet radiator who makes it.
Old Nov 8, 2010 | 10:45 PM
  #139
Brads454's Avatar
Thanks guys!
We had to shim the box because when we had the Camaro accessory setup on it at one time.
That's a Ron Davis Radiator and fan setup, with their overflow. They have it setup for this conversion, it's a new part number they just released.
Old Nov 16, 2010 | 08:54 PM
  #140
Sunobovich's Avatar
Hey Brad, Jim. This is Bruce in Pleasanton with the '62 Impala SS I had for sale. Your car looks great! Was wondering if you ever thought of running rack and pinion steering? I saw a kit for it a while back on e-bay but wasn't impressed with it. Hope to get up to your place this weekend, time allowing. I'd like to check it out.
