240sx+lsx=cool,but add T76 and sy/ty=Nuts?
#88
I don't know who's project this is, but as an owner of 7 240sx's and two
C5's ide just like to say your nuts...and i'm jealous!!!
Good work man, crazy project!
![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
#89
i love your car. this is the same project i wanna do.
do you have a ful parts list, like everything you needed? i really wanna do this, but i have never done anything like an engine swap...
#93
This project is not dead although it spiraled way out of control (budget wise), I also had on one of those adjustable rate mortgage deals, so that sucked up some excess cash for a while.( I got that all straightened out, its actulay less now than before the adjustment) I got to the point where everything is mounted and front suspention was built. Its all back apart now to make some tweaks and go back at it. I also took a break to put heat and insulation in my garage so I can work on it over the winter. (The high for to day is 6 degrees it was -4 when I left for work!!)
I'm also still gathering parts. I just got my 160# injectors if that gives you an idea of the kind of power I'm after.
#97
No sy/ty runs same tires and ratios. So much has changed since the beginning, and I may end running the same ratios front and rear. I don't like the idea of staggered tires so im working on another solution. I don't post much because until I have it nailed down its pointless.
