S&P compressor and bracket kit for sale
Old May 29, 2008 | 10:14 AM
Rodder's Avatar
Default S&P compressor and bracket kit for sale
https://ls1tech.com/forums/lsx-parts-sale/928804-s-p-ac-compressor-bracket-kit.html
Old May 31, 2008 | 06:21 PM
Rodder's Avatar
Old May 31, 2008 | 06:23 PM
70LS1Nova's Avatar
will it work with a vintage air kit?
Old May 31, 2008 | 06:37 PM
Rodder's Avatar
Couple of reasons I'm not using it...
1) the S&P kit eliminates the spring loaded tensioner and instead uses a tie rod with heim joints to statically tension the serpentine belt. I have a hard-on for spring loaded tensioners, and a religious objection to using heim joints for anything on a street car. If I had known this beforehand, I never would have ordered it.
2) too dang shiny for my tastes. I put split tubing over my Lokar throttle cable because it was too shiny, and every thing else under the hood is flat black or cast aluminum.
I'm going to use a Kwikperf bracket kit instead, with an off-the-shelf compressor from Arizona Mobile Air.
Old Jun 5, 2008 | 01:40 AM
Rodder's Avatar
Sorry, didn't see your (editted?) question before! Yes, it should work with the VA kit.
It comes with a polished SD5H14--that's the R134a replacement for the old SD508. It's Sanden list #S6669 (Omega 20-10075), vertical fittings, 12V PV7 clutch. All the SD5H14 have identical mounting dimensions. The S&P catalog shows it has "AN8 and AN10" fittings, but according to the Omega catalog, S6669 should have #8 O-ring and #10 O-ring, which is what the 135deg fittings in the VA kit are for. I haven't uncapped it to confirm which fittings are there. Actually, the cylinder head definately has O-ring fittings, the only question is whether there are flare adapters pushed (pressed?) into the ports. If it's got flare adapters, you should be able to remove them. And if you want to run braided stainless lines instead of the VA rubber hoses, you'll probably still want to remove them and use the Aeroquip AC O-ring fittings instead of normal AN flare.
Old Jun 5, 2008 | 04:32 PM
Novas Forever's Avatar
Hey Rodder:
I had the same thought as you concerning the 'bling' and lack of tensioner, not interested for my Nova. I have the KWiK brackets on mine and can hardly wait to start it up. They are nice.
Old Jun 24, 2008 | 12:29 AM
Rodder's Avatar
still for sale, make me an offer.
Old Jun 24, 2008 | 02:14 PM
BBPanel's Avatar
Veteran: Marine Corps
I hate S&P website - do you have a link showing how it mounts on the block? Thanks. -Bob
Old Jun 24, 2008 | 02:35 PM
Rodder's Avatar
See picture B on this page: http://www.hotrodlane.cc/08%20catalog/page%2090.pdf
Old Aug 4, 2008 | 09:19 PM
Rodder's Avatar
still for sale
Old Sep 5, 2008 | 01:02 PM
Rodder's Avatar
price dropped to $500, tired of it sitting around
SOLD!
