LSx into Jet Boat??
GOOD luck in your search dude !!!
Formula, got your message, just wondering if I should start a new project. Give me few days to think about it.
Will post more pics of my progress soon. I think i also found a cheap set of 243 heads, so I may swap those on too, in order to bump up the compression from 9.5 to 10.5.
I got them for $400. I picked up the risers from a member on performanceboats for $75 shipped.
I hear that schoenfield headers may be looking into making LSx Jet Boat OT headers sometime soon. If that is the case, these may be up for sale later this summer. This is the kind of project I was going with an all aluminum L33, crash box, lightweight setup. But it's a little too far away to check out.....
http://buffalo.craigslist.org/boa/1681620715.html
The plumbing is real simple, cold water from the jet pump runs into the thermostat housing, there are 3 outputs from the thermostat housing, one to each exhaust manifold, and one to the input of the circulating pump.
When the thermostat is closed all the cold water goes to exhaust manifolds, when the thermostat opens cold water goes into the engine and the warm goes to the manifolds.
I know a lot of the jetboats get by without a thermostat, but when the water is cold here in MO, it's hard to get the oil up to temp. I've had a lot of luck with the preheat setups with a pressure relief bypass and thermostat.
Thanks for the heads up though.
We are planning to do a 6.0 truck motor, Z06 cam/springs/ported TB. Hoping for 425hp/425 ft/lbs+ from it.
GTO oil pan should provide the clearance we need.
Stock LS1 manual flywheel bolts up to the splined adapter plate that mates up to the BorgWarner direct drive prop setup. Bellhousing is BBC/SBC and mates up fine. Motor mounts from the BBC came with the boat and should work for our application running adapter plates.
Just need to convert it to fuel injection with a return line on the tank and we intend to run a Vette FPR with 340 Walbro pump. 87 octane is gonna be nice
We have a marine alternator that came with it. Do we need to run a marine starter? If so... why? Less electrical arcing to prevent fuel vapor explosion?
I would also suggest hard lines for all pressurized fuel line. USCG requirements are based on burn time for pressurized components. Although yours wont be USCG tested, it will follow the general industry practice.
Just good ideas in case of an "incident".
