99-02 schematics
Old Jun 11, 2008 | 07:37 PM
LS1MCSS's Avatar
Default 99-02 schematics
I get a lot of requests for the 99-02 f-body pcm schematics so I thought I would just post them.
Attached Thumbnails 99-02 schematics-ac-comp-controls.jpg   99-02 schematics-air-pump-iac.jpg   99-02 schematics-auto-trans-prndl-sw.jpg   99-02 schematics-auto-trans-stop-lamp-sw.jpg   99-02 schematics-bcm-fuel-pump.jpg
99-02 schematics-bcm-cc-ebcm-ipc-radio-vss.jpg   99-02 schematics-cc-ect-oil-level-generator.jpg   99-02 schematics-ccsw-manual-trans.jpg   99-02 schematics-cmp-ckp-ks.jpg   99-02 schematics-cooling-fans.jpg
Old Jun 11, 2008 | 07:40 PM
LS1MCSS's Avatar
Default More
These will complete the set.
Attached Thumbnails 99-02 schematics-dlc.jpg   99-02 schematics-engine-sensors.jpg   99-02 schematics-evap.jpg   99-02 schematics-fuel-injectors.jpg   99-02 schematics-fuel-tank-unit.jpg
99-02 schematics-ignition-system-bank-1.jpg   99-02 schematics-ignition-system-bank-2.jpg   99-02 schematics-oxygen-sensors.jpg   99-02 schematics-pcm-power-ground.jpg
Old Jun 14, 2008 | 09:48 AM
jannes_z-28's Avatar
This should go in the stickies!
Maybe a new thread for electrics and wiring in the stickies.
Jan
Old Jun 14, 2008 | 07:29 PM
LS1MCSS's Avatar
It's much easier to mod your own harness when you have these instead of just pinouts.
Old Jun 22, 2008 | 11:27 PM
badinfluenceRS's Avatar
Thanks for posting these.
Old Oct 30, 2008 | 06:08 PM
LS1MCSS's Avatar
Bump this back to the top for the people asking for it.
Old Jan 2, 2009 | 09:26 PM
LS1MCSS's Avatar
Bump back to the top. I have several requests for these.
Old Jan 3, 2009 | 03:01 PM
snketr's Avatar
This should be a sticky. I have the complete alldata for myself, but very few have the ability like us to get these. Thanks for sharing with the rest of the community.
Old Jan 4, 2009 | 12:38 PM
busta9876's Avatar
for those new to reading these diagrams, this might help
Old Jan 4, 2009 | 01:04 PM
LS1MCSS's Avatar
That will help a lot and you did a good job on it. thanks
Old Jan 5, 2009 | 12:01 PM
Nemesis68's Avatar
Thanks
Old May 12, 2009 | 10:27 PM
flipsta510fazn's Avatar
i need some help okay i have a 67 camaro that im doing an ls1 swap with a t56 and i need help doing my harness and i want to do it myself while people on the board says its easy can someone please direct me to the right direction
thanks
louis
Old May 12, 2009 | 10:47 PM
THE1320's Avatar
you wouldnt happen to have these diagrams for a 02 s10 with 0411 pcm would you. im getting ready to mod my harness and have been looking for these. thanks for the ones for the fbody.
Old May 12, 2009 | 11:19 PM
G-Body's Avatar
sawzall wielding director
thanks
louis
Have you checked out the FAQ sticky? https://ls1tech.com/forums/conversio...swap-faqs.html Theres a lot of useful info in it, great place to start. Post 13 has links to wiring info.
Old Jul 6, 2009 | 04:33 PM
BlackTA96's Avatar
damn.
This needs to be a sticky!!
Old Mar 6, 2010 | 06:57 PM
mrmarchuk's Avatar
thanks a ton
Old Mar 6, 2010 | 08:59 PM
N21923's Avatar
Thanks. Got them for a 04 GTO? I need the AC circuit.
Old Aug 1, 2013 | 02:55 PM
Gordon33's Avatar
Default Thanks
Thank you!!!!!!!!!!!!!
Old Dec 29, 2013 | 11:42 PM
chevySS425's Avatar
Hey thank a lot
Old Jul 15, 2015 | 05:33 PM
LSD-150's Avatar
LS1MCSS, just wanted to give you a quick thank you for sharing that info with everyone. I have a fairly involved project coming up, and these wiring diagrams will help immensely.
