Circuit 1020: Where is it at?
I need 12v at Pin E of connector and according to this diagram it will be circuit 1020:
http://www.ls2.com/boggs/a4/autotransinlineharness.htm
And I am not sure where this wire comes out of the PCM, b/c 1020 is not listed in this:
http://www.ls2.com/boggs/torques/2001pinpcm.htm
From some searching this circuit is located at pin out 75, but not sure it is the blue or red and from the pinout above it shows this is not used so how does the trans/selonoids get their needed voltage to operate, hence why mine is not working right, it is not getting 12vs at the connector at the trans.
