Carshopinc.com starts a ls swap
Old Jul 8, 2008 | 07:51 PM
01WS6/tamu's Avatar
What are you using for an oilpan. I went ls2 pan on my truck.
Old Jul 8, 2008 | 09:35 PM
Nashty's Avatar
Lookin' good - the Blazer, not the mechanic (YIKES !!!)
PS, the headers fit great although my motor mounts didn't like them. Headers win.
Old Jul 9, 2008 | 09:05 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
Got any pics of the mounts fighting the headers? I am going to hack at the frame today I hope!
Old Jul 9, 2008 | 09:06 AM
LS1TECH Sponsor
lh8 pan......... For the win!
Old Jul 9, 2008 | 09:17 AM
LS1TECH Sponsor
Hey ls1blazer I read your thread about the lh8 pan not allowing for trans removal, did you ever rectify that problem? I want this to be serviceable for that just "in case" situation...
Old Jul 9, 2008 | 05:00 PM
ls1blazer's Avatar
The blazer may give you enough room to get to the top bolts . But on the s10 truck I'm working on now with the H3 pan , The notch is the way to go . I can tilt the trans enough to get the top bolt in by hand . The trans can be removed in less then an hour. Since the engine sets higher in the blazer, it might tilt enough to get the trans out. On the trucks,the pan is almost touching the crossmember(1/16"). I actually shim the transmission up 1/4" to give the pan a little more room to move. I'm going to notch the crossmember regardless now unless the owner does'nt want to .
Old Jul 10, 2008 | 12:09 PM
LS1TECH Sponsor
I cut cut cut today......!
Planning on finishing the fuel system today and putting the el motory back in to finalize fitment before we send it to the welder..... We know a guy who knows a guy......
And knowing is half the battle!
Old Jul 12, 2008 | 04:15 PM
LS1TECH Sponsor
Thanks to Tim g we now have a boxed frame ready for a scuff and paint job.....
Old Jul 13, 2008 | 12:35 AM
fenton06's Avatar
lookin good... welds look top notch!
Old Jul 13, 2008 | 09:02 AM
LS1TECH Sponsor
Yeah he has some talent......
Old Jul 15, 2008 | 04:52 PM
LS1TECH Sponsor
Not much new just painted the frame today....
Old Jul 16, 2008 | 09:47 PM
  #32
Nashty's Avatar
Looking good, slow down though, sheesh.
Got the mounts and headers to live in harmony.
Passenger side from above
PS from front
Driver side from rear
Old Jul 17, 2008 | 01:16 AM
  #33
Jaysz28's Avatar
Active Streak: 30 Days
Nice work
almost convinces me not to attempt this!
-jason
Old Jul 17, 2008 | 07:44 AM
  #34
LS1TECH Sponsor
Roger your a artist!
Old Jul 17, 2008 | 04:27 PM
  #35
LS1TECH Sponsor
We worked on the truck for a little bit today, With the ls1 conversion and the engine harness we are using we need to use the stock s-10 nuetral saftey/gear selector switch assembly.....
The F body gear selector was not designed for this but all of the gm 4l60e cases were setup to be compatible.....
The F body selector shaft is much shorter and will need to be replaced with the unit from the s-10 (if you have a unit from a truck it should already have this switch assembly).
Here is the f body
and here is the s-10
In order to work on the trans I used the engine hoist to lift the unit up to a back friendly level....
I order to remove the shaft you will need to remove the retaining clip and this 15 mm nut
Then the shaft can be removed.........It is similar for both the truck and car, you will need to remove the retaining bolts and wiggle the neutral saftey switch off the truck trans and reverse this complete process in the F body trans....... Pretty simple stuff!
Old Jul 17, 2008 | 04:28 PM
  #36
LS1TECH Sponsor
Almost forgot the PIC
Here are the two shafts side by side........
And here we go all installed (never mind the orange goo I need to clean it up still)
Old Jul 18, 2008 | 08:17 AM
  #37
yecker's Avatar
Hurry up and finish this one so you can help me with my S10
Old Jul 18, 2008 | 08:56 AM
  #38
Elec87's Avatar
Do you mean my new s-10..... I will be up with the trailer this weekend.....
Old Jul 18, 2008 | 09:07 AM
  #39
yecker's Avatar
Ha....you at least have to let me get tired of it.......so wait till next weekend..lol
Old Jul 18, 2008 | 01:17 PM
  #40
LS1TECH Sponsor
Next weekend it is!
