Carshopinc.com starts a ls swap
project 97 blazer 2 wheel drive 4 door.........
1999 ls1 4l60e
Nothing toooooo special but we are working our **** off to get this done soon!
Going to try this pan!
We had to elongate and offset the trans mount hole in the crossmember (mills are cool!) The crossmember sits in the stock location and bolts back in like stock.
Next we ground the passenger back valve cover coil mounting tab to clear the heater box..... AHHHHH who needs that one!
Drivers side is purty close, going to have to use the truck coil brackets for this one!
Now on the two wheel drive s-10 trucks gm raised the engine up to improve drive line angles, they are about 1 1/4 higher. With the addition of the lh8 pan we do not have any ground clearance issues or frame modifications to physically install the engine, however we will still be modifying the cross member so that incase of a trans failure the engine will have ample room to rock down allowing easier access to bolts.
http://www.s10forum.com/forum/f213/c...blazer-359941/
I then modified the stock bracket and the throttle cable and cruise cable work just fine! (open the hole up a little)
