Where is my VIN?
Old Jul 7, 2008 | 10:43 PM
s10_xtreme's Avatar
Default Where is my VIN?
From what I've seen on here everyone says its on the drivers side by the bellhousing. Well, mine is not. Is the partial vin placed anywhere else on a 2003 engine.
Old Jul 8, 2008 | 12:27 AM
Lilscottie's Avatar
Not sure about in the US.
But here in AUS. a VIN is a Vehicle Identification Number, Which is usually found on the cars chassis.
Someone correct me if It's a different story in the states.
Old Jul 8, 2008 | 09:44 AM
s10_xtreme's Avatar
I've only got the engine, never even saw the car it came from. So....
Old Jul 8, 2008 | 09:55 AM
stealth71's Avatar
Do you have the PCM? I think it's in there as well.
Old Jul 8, 2008 | 09:56 AM
V8Rumble's Avatar
No, that's the typical usage up here as well. To the OP, I don't have much knowledge of 2003 engines, but I'm sure that someone will be able to give you the answer shortly...
Old Jul 8, 2008 | 01:25 PM
69LT1Bird's Avatar
That is where its supposed to be. Perhaps the block was decked and they machined it off or perhaps a service replacement or worse, theft and sanded off. Go for number 1 or 2.
Old Jul 8, 2008 | 04:07 PM
s10_xtreme's Avatar
I was afraid of #3, and its not number 1, hmmm... not good.
I think I'll check with the member i bought it from. Thanks, just making sure I'm not missing something obvious.
Old Jul 8, 2008 | 04:13 PM
s10_xtreme's Avatar
Also, whats that number in dot matrix under the 241 casting on the head?
Old Jul 8, 2008 | 07:07 PM
01WS6/tamu's Avatar
what are you needing it for.
Old Jul 9, 2008 | 04:22 PM
s10_xtreme's Avatar
carfax/curiosity
Old Jul 9, 2008 | 04:36 PM
Stu Cool's Avatar
The should a laser etched number on the driver side just ahead of the bellhousing. It runs up and down. Not always easy to read. This is only a partial VIN but can be used to make a best guess at what it should be. Here is a link that will help you.
https://ls1tech.com/forums/showpost....0&postcount=12
Here is another link
http://www.f-body.org/oldfaq/html/vins/4genvins.html
hope that helps
Old Jul 9, 2008 | 06:43 PM
philntx's Avatar
Are you guys sure that there is a vehicle identification number (VIN) stamped on the engine that corresponds to the VIN on the Dash?
I'm thinking the number on the engine block is a serial number that might somehow describe the engine, but not the vehicle.
Old Jul 9, 2008 | 07:09 PM
01WS6/tamu's Avatar
To the best of my knowledge the infor on the block is the last 8 of the VIN. I thought you may be hunting it for pcm programming reasons.
Old Jul 9, 2008 | 09:20 PM
philntx's Avatar
I bought a crate LQ9. There was a laser etched number on it, but since it was never installed in a car, I just "assumed" that it was a S/N
Old Jul 9, 2008 | 09:26 PM
philntx's Avatar
I bought a crate LQ9. There was a laser etched number on heads, but since it was never installed in a car, I just "assumed" that it was a S/N.
The LS1 has a casting number of 12559378, 12560626, 12561168 (LS6 block)
Machined numbers might be something like: 12559379, 12560625 or 12561167
Not sure if this will help.
Your best bet would be to contact the person who sold you the engine and ask for a copy of the title of the vehicle that it was removed from.
