Decent day at the track
I was running the car in my sig. I currently have no HPTuners cause it broke, so im running my rich/very safe 10psi tune from last year. Had it set up for wastgate boost only, about 7psi. I topped off with 89 octane, drove 60 miles to the track and went right to tech then staging. didnt let the car cool down and left my street tires on which are 255/60-15 firestone indy 500s. Proceeded to run:
60'-2.069
1/8th-8.08
mph-93.59
1/4-12.260
mph-116.41
This run i left at about 2400rpm, 3-4psi and it hooked good but didnt spool very well. I made 3 more runs on the street tires trying to hit them a little harder but just spun. This led to me putting the DRs on, BG 275/60-15. First run with these i did a small burnout and left reasonably soft, bout 2800 and 5psi and they hooked. Ran:
60'-1.80
1/4'11.59
mph- about 118
Forgot the timeslip in the car
Next run i didnt get into the tree fast enough and left soft again:
60'-1.821
1/8-7.522
mph-96.24
1/4-11.614
mph-118.54
After a hour cooldown the clouds were coming in and i went for one more. This run i launched as hard as i thought i could without the car rolling. My front pads are so glazed they dont hold very well. Launch was about 3200rpm, 6psi and it held:
60'-1.766
1/8-7.358
mph-97.65
1/4-11.425
mph-118.95
Video: http://www.youtube.com/watch?v=7cJ5_Y6Bneg
Some additional specs on the car, it was around 3780 raceweight today, stock body and full interior. Sub box in the back and everything, almost have the A/c back on too. Also it is more set up for driving with terrible front shocks and springs for drag, and full swaybars. I race it just as its driven every day. The engine has another 50-75hp in it on pumpgas, and i dont have an intercooler either. If i remember right these runs should be about 550-575 crank hp, the MPH isnt there because most racers were 4-5mph slower than normal in the wind. I think someone else got some other vids as well, i will post up if found.
Gary
Just being tough on a fellow turbo buick owner. Also, are you running a brake? If not you can buy two sets of rear pads and put both of the long shoes on each side. Easy way to hold boost at the line.
