lsx fox body guys, which radiator?
Old Jul 15, 2008 | 10:30 PM
Crowder's Avatar
Default lsx fox body guys, which radiator?
which radiator are u guys using? thanks
Old Jul 15, 2008 | 11:00 PM
Hibs's Avatar
I thought i read you can use a stock Fbody radiator with minor modifications.
Old Jul 15, 2008 | 11:02 PM
jw33's Avatar
stock F-body fans and radiator. It fits perfect.
Old Jul 16, 2008 | 02:11 AM
1dirtyZ's Avatar
yup , stock f-body fans and radiator, you will have to let the radiator sit on the ford AC condenser mount ( it has to be tilted like on an f-body).
Old Jul 16, 2008 | 04:50 AM
Shawn MacAnanny's Avatar
The 94 Camaro/firebird radiator has the thickest core (best for cooling. After that they got thinner and thinner. LS1 being the thinnest.
Old Jul 16, 2008 | 04:07 PM
mulletnotch's Avatar
I used a large aluminum aftermarket radiator for a C5 in my 90 Mustang. It fits great. I used the factory hold down up top on both sides and was able to use the factory lower bracket and rubber grommet on the drivers side, on the passenger side the radiator had a large "dowel" rather than the flat front to back tab.... I drilled a hole in the core support large enough that the "dowel" would slide down into it. To cushion it I placed a thick piece of rubber similar to what the factory uses. It slides over the dowel and the radiator rests on it. Pretty clean and simple for anyone that has access to a Vette radiator and wants to use it.
Old Jul 17, 2008 | 10:59 AM
Crowder's Avatar
hey mullet, my buddy has an aluminum radiator in his and he still has his stock one u think i will have any over heating issues with this and a massive s475 sittin near it?
Old Jul 17, 2008 | 11:09 AM
nuckifuts's Avatar
why do you say that? the reason it is tilted is because of the nose of Fbodys being sloped.
Old Jul 17, 2008 | 02:07 PM
Should be more than enough. Be sure to run good fans or one good fan.
