I need some help with a 1998 Chevy truck
I just put a ls1 in a 1998 chevy truck. I used the carb setup with the msd box. I am needing info on the 1998 truck harness in order to run the stock gauges. Pinouts for this truck will be great if someone has them. The truck originally came with a 305 and a 5 speed. The computer plugs and such are still in the truck.
Thanks in advance!
Eric B.
Thanks in advance!
Eric B.
Eric
1996 and 1997 are supposed to be the same but there was a couple wires that are different on my 1997 swap.
I have read that 1998 are a lot different from 96 and 97.
As far as the 1999+ 2500's I have no idea if the 1998 are the same.
I can email the pinouts I used if you want to pm me.
Good luck
Good luck
Your best bet...
is to buy a GM Factory Service Manuel from E-Bay. This is what I did. It has everything in it that you will need & more. Invaluable. 1996 , '97 & '98, were transition years for GM trucks & each of those years is a little bit different in wiring, computer & controls. They are a two volume set, but I think its just Volume 2, that is all you need with regards to the wiring, connections, etc...
