L92 engine harness options
Having to change the oil pump and lifters is for the engines with DOD not with VVT from what I have read. It seems a lot of people are confusing the two.
The L92 doesn't have DOD. The DOD engines need the higher oil pressure to activate the lifters to seal off the 4 cylinders not being used.
The DOD oil pump is not higher pressure, it is higher volume. Up to 30%.
DOD engines have an extra oil pressure regulator to ensure the pressure does not get too high, i.e. around 65psi.
The reason for the extra volume is to support the DOD oil requirements
: re-activating the DOD lifters, and maybe the less important fact that the solenoids for DOD actually leak full time. By design.
If you have an LS2 harness for an E38, should work fine.
i think that still has cam sensor in the back of block,,doesnt it?..we just pulled an 05 lq4 and it was in the back,, l92 cam sensor is in front,,like ls2 style,, im pretty sure you would need to modify harness,, has to reach cam sensor and have right plug for e38.. 58xtooth controller..
ive been racking my brain out for the past week trying to figure out all this newer stuff,,!!!
but if you wanted to put it in an genIII truck,i think easist way to do it is get the 58xt converter box to 24xt,,and a exstension harness for your cam sensor,, and i think you can run your stock pcm,,but cant use the vvt,,you would have to have e38 ecm..,this is from what i understand,,im no proffesional..maybe some one else can chime in..
So the l92's are 24x...hmm. and yea im tryin to keep it simple so I will be doing away with the vvt. If the cam plus just needs to be extended to the front, that shouldnt be an issue, I am wanting to rework the harness to make it a bit cleaner looking anyways.
