LH8 conversion oil pan, need sensor?
Old Jul 28, 2008 | 11:43 PM
thunderstruck507's Avatar
Default LH8 conversion oil pan, need sensor?
The pictures I'm seeing of this pan don't seem to have the sensor like the fbody pan.
Is this an issue?
Old Jul 29, 2008 | 12:26 AM
bczee's Avatar
The sensor in the F-body pan is for the oil level sensor... not needed, flash it out...
Old Jul 29, 2008 | 10:21 AM
thanks!
Old Nov 23, 2008 | 02:54 PM
mind's Avatar
do you have to flash this out for the car to start?
my car won't get gas or spark and i'm stuck.
the oil level sensor is not hooked up.
Old Nov 23, 2008 | 03:24 PM
mind's Avatar
i read the oil level sensor goes straight to the dummy light, therefore i assume it has nothing to do with the computer at all.
Old Nov 23, 2008 | 03:44 PM
Smo's04Gto's Avatar
used the same pan,engine started without changeing the pcm
