Can't decide BB or LSX?
the only advantage a BB gives you is you can say its a BB. Looks, oohh-ahhs's etc.
A modern LSX will get much better mileage, and if you have to have 572cu like torque, toss a roots on it, and still get good mileage.
Now I have a chance to get a wrecked 1999 Camaro with the LS1.
I was surprised to see how many said they would pick the big block.
I have heard great things about the LS1, that is why I have decided to do the swap, I hope I made the right choice.
Also want to think everyone at LS1TECH for the information I have found. I'm sure I have found all the info to complete the build just by using the search function.
Downside=$$$$, ask me why I know.
Before the swap i had a world engines 509 all aluminum bb. That thing was insane when you hit 3000rpm and i will never forget the sound or the feel of that engine. It was like a drug to drive the first 30minutes, but after that it just started getting annoying more or less.
The ls engine have made the car much more pleasant to drive. Better mpg, superb idle, more comfort, less noise, and it is still very fast. almost as fast as the bb. It is only after 80mph i can feel the bb had more torque. Can't tell you which engine to choose, but i cant tell you whether you pick the ls or bb, it will be 2 totally different cars you'll be driving.
put it this way. you can get a complete ls2, not not even ls1, with low miles (used) for around 3.5 to 4k with a trans of your choice. thats 400hp, box stock.
phr had an article a while ago, threw an ls2 on the dyno with 1 7/8th headers and made 472hp/450ft lbs. then, with h/c/i it made 57xhp/500ft lbs. out of what 362? ci? thats awesome. and the fact that its so simple to make the power, and SO drivable just sweetens the deal. there are so many advantages to the lsx its just like... why get a 502... when you can have an lsx. especially in a street strip car. then you tell them its just a stock motor out of one of those slow gto's as you mop the floor, run 10's, and cruise home.
67 Coronet 440 vs 71 Torino GT conv 351 clev.
http://s282.photobucket.com/albums/k...t=MOV07326.flv
71 Torino GT conv 351 clev vs 1965 LS1- F85
http://s282.photobucket.com/albums/k...t=MOV07327.flv
Final match up
67 Coronet 440 vs 1965 LS1- F85
http://s282.photobucket.com/albums/k...t=MOV07328.flv
I sure like that passing gear..................................
Final match up
Tails
