My 72 chevelle build thread
Old Nov 19, 2008 | 01:47 PM
72chevelle6.0's Avatar
Default Wiring
I have been working on the wiring while I have spare time at work. Time like this I am glad I work for myself.
Plan is to reroute the wires to run to the back of the motor so i can mount the PCM and fues bow under the dash.
Old Nov 19, 2008 | 02:34 PM
bczee's Avatar
Yeah.. that is what I did when I removed the extra wires and connectors, re-wapped the harness and I have the PCM mounted on top of the Trans Tunnel with a console hiding it, Gauges and Idiot light are also in the console.
Old Nov 24, 2008 | 10:56 AM
Got some work done again. I am moving also and I have been working on the house so progress is slower than wanted.
Here are the oil coolers one for the trans and one for the engine oil.
Got the A/C firewall box out the way just need to plug the holes.
Here is my remote transmission filter I have the remote filter for the engine oil in the same place on the driverside.
That is most of what I got done. I tore out the carpet since it needed replacing anyway and I needed the room so it is easier to work with out the seats in the way.
Old Nov 24, 2008 | 01:37 PM
stealth71's Avatar
Looking good. Are you planning on running a thermostat on the oil cooler? It would be a good idea.
Old Nov 24, 2008 | 01:59 PM
I had not planed on it. Wouldn't i have to do extra plumbing for some kind of bypass?
Old Nov 29, 2008 | 10:25 AM
Moving the motor home.
Getting it dropped in
In its new home
This is just a cool picture
Here is the Alt. clearance
Wiring "roughed it" Still need to remove a wire or two and try to make the lengths more uniform. The the ODBII port and fuse box.
Old Jan 7, 2009 | 09:37 AM
Well I have been steadly working on it. I this I will get to fire it tonight or tomorrow. I will not get to drive it till my HPTuners Interface gets back it had problem of some kind. I still need to wire the Fuel pump up and hook the engine Fuse box to the coil wire to trigger the relay. here are a few updated pictures.
Old Jan 8, 2009 | 11:21 AM
68 TT's Avatar
Default electric fans
What application area those electric fans off of? They look like a nice fit for a lot of swaps into older vehicles.
Old Jan 8, 2009 | 11:26 AM
they are from a 2000 camaro or they come on the TA's also.
Old Jan 8, 2009 | 12:56 PM
68 TT's Avatar
Thanks, I was hoping they weren't from a F*rd.
Old Jan 8, 2009 | 01:01 PM
haha No Problem..
Old Jan 9, 2009 | 10:16 AM
  #32
well the walbro pump i bought from a member here is junk sounds like it have something loose in it and is not pumping. I just ordered a holley from the parts store they will have it tomorrow by noon.
Old Jan 13, 2009 | 11:12 AM
  #33
the Holley pump is the GSL392 that walbro makes.. I got the car to start for the 3 sec that I can with the vats still on. hopfully HPtuners will get back today or tomorrow. here are a couple of videos the sounds does not do it justice.
View Video on FQuick
Old Jan 13, 2009 | 11:37 AM
  #34
pist0lpete's Avatar
Congrats! Doesn't it feel nice to fire it up?
Old Jan 13, 2009 | 11:41 AM
  #35
Thanks and heck yeah it felt great.. I know Bill at HPtuners is tired of hearing from me I keep asking about the interface I can't wait to get the Vats disabled so I can start tuning.
Old Jan 13, 2009 | 12:54 PM
  #36
stealth71's Avatar
Nice. Congrats on getting it fired.
Old Jan 14, 2009 | 10:57 AM
  #37
68 TT's Avatar
Default Vats
Any idea how VATS works on the LSx PCM's?
I am used to the OBD-1 version with a chip in the ignition key with a sensor module under the dash that can be physically bypassed with no software changes required. I did this with my 91 Camaro when I put a non-computer controlled engine in it to turn it into a drag car. The ECM was no longer in the car so even with the right chip in the original key it would not start. The VATS module just worked like a relay so I was able to bypass it so the ignition system functioned. The inverse should be true so you should be able to wire the PCM sensing wires to think the VATS module was present and working without it present.
If it is similar to the older systems then it could be as simple as supplying voltage to a sensing wire or connecting two wires going into the PCM to physically bypass VATS. Basically tricking the LSx PCM's so the system thought the VATS module was sensing the correct key all the time.
Old Jan 14, 2009 | 11:10 AM
  #38
I think that on the LS1 PCMs you can get a device that can trick it but on truck I think it is a little more to then that. also since most people get their computers tuned anyway it is just easier to have it turned off.
Old Jan 19, 2009 | 10:43 AM
  #39
ok I got it to Idle last night after lots of work. here is the video..maybe to night I will get to drive it.
Old Feb 5, 2009 | 05:06 PM
  #40
well I have been working on the tune with the help of a board member. so I have been driving it.. here a shot of it at work and a couple of the intake I made for it still need to make something to keep raod grime from the tire off the filter.
