My 72 chevelle build thread
I later built an enclosure to seal it off from the engine compartment heat so it only pulled air from behind the headlights. This was a noticeable improvement in power when the car was fully heat soaked from driving.
Ext. Oil Filter mount with two 1/8 NPT fitting for temp gauge sensor
-6 lines that run from the trans to filter and cooler
Like New B&M hammer shifter
trans as a core with stock converter
The 3000 stall TCI converter if it is still good
Autometer trans temp gauge.. that all I can think of right now..
I had fun with the Auto while it lasted..
