Porsche 914 LS6
I've also seen converted 914s w/ 350 v8s sell for $7000, albeit, not the newer ls1 motor. If you want the 930 transaxle, yes, it starts getting pricey. But you won't build a sicker car with awesome braking, handling and acceleration for under $20k. Using an older 350 and 901 transaxle, you are at about $10k. If you want the excellent brembo brakes, those are $2000. But, the BMW 320i front calipers work pretty good after replacing the rear proportioning valve (I did that on another 914 that I have). BMW 320i calipers are about $65 from Pepboys. Depends what you want... A 2010 Ferrari killer or a 2010 mustang killer.
Here's what we're now autocrossing and part of the reason I'm here! We're looking to ditch the current engine for some LSx motor. This is a 355 SBC but it's an iron block, 11.1 comp, carb, and distributor. We'd like to use pump gas instead of race gas, with better and more consistent performance.
![](http://www.daculaweather.com/stuff/914/P9080011.jpg)
![](http://www.daculaweather.com/stuff/914/P9080017.jpg)
It's suppose to be a '69 Z28 block. I'm pretty sure the LSx bellhousing is a different bolt pattern? I believe we'll need to get a different adapter than we have now.
Actually no, they are the same pattern (missing a bolt or two). But there are some (lengthwise) spacing issues-and aftermarket fixes too.
A LSx will bolt right in with the correct adapter plates. Just need to figure out which oilpan and exhaust headers work best.
