LS1 Starts then Dies after 3 seconds
I have the same problem. I have swapped a supercharged 6.0 into a 68 camaro. The motor starts runs for about 4 or 5 seconds then dies. after I have tried for a few times And the motor is warm I can hold the throttle about half and when the motor starts it still dies but if I continue to hold the throttle it will pick back up run for a few and do the same. It will continue to do that I definitely I have sent the computer back to blackbear performance twice and they say they have disabled the VATS I have tried two different harnesses and checked the grounds numerous times. I have bypassed the harness for the fuel pump and the power for the ECU. Still does the same
Originally Posted by Joshua Hill
Do you have the mass air flow sensor on it? Even though I had changed to speed density I still had to run the mass air flow sensor to get mine to run for more than a few seconds.
Did you figure this out? What did it end up being? I have almost the exact issue now. TIA
