Carb Guys: Timing Question
Old Aug 25, 2008 | 08:27 PM
94snake's Avatar
Default Carb Guys: Timing Question
Im asking this for a friend. He's got a 6.0 in an '82 S10. Its got 5.3 heads, MS4 cam, Edelbrock carb intake, shorty headers and the adjustable MSD timing controller. What do you reccommend for a base timing setting? Also, what would be considered as a 'max' setting?
He's gonna spray it in the future, but will be NA for now.
Thanks.
Old Aug 26, 2008 | 06:09 AM
Shawn MacAnanny's Avatar
i have 15 degrees at idle, going up to 28 by 3000 rpm 28 is max with my setup i would suggest 24-26 with his since he has higher compression with the 5.3 heads. He should also run NGK TR6 plugs which are 1 stage colder. Is he running a MAP sensor?
Old Aug 26, 2008 | 07:21 AM
SMAX's Avatar
With that cam you will probably need more initial timing maybe 20-22* from 0-1000rpms and as far as total timing he is probably going to have to do some adjusted, but I would start at 28* in by 3000rpms and go from there. I don't think there is any need to run colder plugs NA.
Old Aug 26, 2008 | 07:33 PM
Roller406Bu's Avatar
I have 32 from 3000 all the way up on mine....ms4 cam, tr6's 93 octane at all times...my heads are shaved....
Old Aug 26, 2008 | 08:03 PM
94snake's Avatar
The truck has Tr55s in it now he has a Holley 750 street HP on it and 11.1 Compression.What plug would be good and what should he gap it at?
