67 camaro Ls1 brake problems
Old Aug 27, 2008 | 12:16 AM
59 camaro's Avatar
Default 67 camaro Ls1 brake problems
https://ls1tech.com/forums/showthrea...94#post9995494
Old Aug 27, 2008 | 02:20 PM
67rsss's Avatar
Check and make certain that the pushrod between the booster and the master is the correct length. If you used to have drums, and now have disc in your 67, you may not have the correct booster to master rod.
