LQ4 into a 3rd Gen/1972 Nova
Old Apr 5, 2012 | 10:21 PM
  #821
Marktainium's Avatar
I agree with tiresmokin. O-Ring on tube first. If you put it in the pump first there is a pretty good chance that the tube will push it into the pump and give the classic low oil pressure symptoms. The oil pump swap is a good idea, but a lot of work. You can also get away with doing the spring swap in the pump which you can do without removing the pump IIRC.
My turbo's do the same thing as far as free-spooling. I was concerned at first because one was less spinny than the other... after some use they break in I guess because they spin ok now.
Old Apr 6, 2012 | 02:35 AM
  #822
frojoe's Avatar
Originally Posted by Marktainium
Here's some inspiration....
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-17971183.jpg
Old Apr 6, 2012 | 10:36 AM
  #823
frojoe's Avatar
Cool, thanks for the info. I'll have a look at this next week. It'd be nice if the o-ring was the culprit, and I'll have to do a bit more research on the easiness of in-car spring swap, I think I might want to do that regardless if it doesn't require pump removal.
And "less spinny"... is that a technical term??
Old Apr 6, 2012 | 11:47 AM
  #824
tsnow678's Avatar
Originally Posted by frojoe
Thats some funny ****!!! You guys act like brothers for sure.
Old Apr 6, 2012 | 12:42 PM
  #825
-TheBandit-'s Avatar
Another vote for the o-ring goes on the pickup first, then into the pump. I don't know if that's causing your problem, but if the o ring is extruded or pinched weird, you'll probably see it when you pull the pickup off.
Old Apr 6, 2012 | 05:53 PM
  #826
I worked at Garrett turbochargers for a while doing rotordynamics and developing bearing systems for advanced dual compressor diesel turbos, including this sequential turbo for Ford which had some rather interesting rotordynamic challenges with all that overhung compressor wheel mass. With this qualification under my belt, you should believe me when I tell you that "spinny" is of course a technical term. It's defined as the third term inverse hypothetical integration constant of the fifth order bipolynomial fourier expansion summed over the square root of the algorythm for determining horsepower where torque and speed are multiplied to produce grin and tire smoke.
Old Apr 6, 2012 | 05:58 PM
  #827
ls68firebird's Avatar
Well since you put it that way.....makes perfect sense.
Old Apr 6, 2012 | 08:33 PM
  #828
Jimbo1367's Avatar
LOL
Old Apr 6, 2012 | 08:52 PM
  #829
Nice!
Old Apr 7, 2012 | 11:34 AM
  #830
frojoe's Avatar
As an engineer... that all made perfect sense. Couldn't have said it better myself.
Old Apr 8, 2012 | 06:33 PM
  #831
hookemdevils22's Avatar
clint, I didn't know you used to work for garrett. I work for honeywell aero, and I've heard that we get a tremendous discount on their turbos. you should've taken advantage.
and the dual compressor setup looks like that in the 85 series APU... designed in the '50s.
Old Apr 9, 2012 | 01:48 AM
  #832
DGGM WX3's Avatar
the 85 is a beast.
Old Apr 9, 2012 | 07:02 PM
  #833
Originally Posted by DGGM WX3
the 85 is a beast.
Hey, you're working in the APU group now, right? I think Richard has done a couple runs with you. I think I moved over to Engines right when you came onto the group. I've been meaning to check the car out sometime...
Old Apr 10, 2012 | 01:01 AM
  #834
DGGM WX3's Avatar
Yep. Your moving to engines allowed me to get hired.. so thanks!
As soon as I get it back on the road, you're more than welcome to
Old Apr 16, 2012 | 06:42 PM
  #835
frojoe's Avatar
Flashed engine with a new tune, idles nice at 675 rpm. Started the engine for about 10seconds to lube the turbo but not long enough for things to really warm up. Blocked off the turbo oil feed line and restarted engine... with the oil still cool and no supply to the turbo it was getting 15psi dropping down to 10psi. ****. Guess oilpan has to come off and investigate the pickup o-ring. Come to think of it I believe I put the brand new o-ring on the pickup tube first, but either way pan's gotta come off.. arg!!!
Old Apr 16, 2012 | 08:01 PM
  #836
350SS's Avatar
possibly porosity in the pickup tube welds? I'm sure you check this though
Old Apr 17, 2012 | 12:18 AM
  #837
Before you do that check the pressure with your old gauge.
Old Apr 20, 2012 | 01:24 PM
  #838
anybody hear from joe? looks like this thread died
kidding, kidding. seriously though, what's the latest?
Old Apr 20, 2012 | 02:06 PM
  #839
frojoe's Avatar
Going to throw a mechanical gauge on there and start it tonight to confirm shitty oil pressure, and if so, it's gonna be a pull-oil-pan-and-check-oring-but-also-probably-replace-oil-pump drinking party tomorrow... craaaaap.
Old Apr 22, 2012 | 05:06 PM
  #840
Chicago TDP's Avatar
When you get close to it, pull the allen plug on the oil pump.
If some reason the bypass plug is stuck, you could be by-passing the oil.
Hope you find a smoking gun though...sucks when you pull apart a motor, make an oily mess only to find nothing wrong...
