L59 questions
Old Sep 7, 2008 | 12:08 AM
nastychevelle's Avatar
Default L59 questions
2002 5.3L L59 engine
vision motorworks 80mm throttle body (will this fit on the stock intake?)
Zo6 cam
LS7 high rev lifters
pacesetter longtubes pypes x pipe with cutouts and magnaflow mufflers
speedway motors TH350 to ls1 kit (th350 2300 stall and b&m shift kit)
tuned pcm
how much power should i expect from this combo(RWHP)?
will 2300 stall be enough for this cam?
should i get an LS6 intake/aftermarket or keep the truck intake for my 4dr 70 chevelle?
oh and how much nitrous can one of these things handle (about 100k mi)?
Old Sep 7, 2008 | 01:48 AM
Hibs's Avatar
i don't know about nitrous, but i know of a certain fairmont with a junkyard 5.3 that is seeing 600+ hp with a turbo, over 150 drag runs, dyno pulls, and thousands of street miles, and it's not missing a beat.
Old Sep 7, 2008 | 10:06 AM
philntx's Avatar
Nice combo. However, knowing the price of gasoline, I'd opt for a built
4L60/65 trans for the OD.
Old Sep 7, 2008 | 08:30 PM
thanks but i plan to use a th350 to keep everything cheap cause i already have one with a B&M shift kit and 2300stall converter
Old Sep 7, 2008 | 09:07 PM
2000lsxs10's Avatar
The thing is about the l59 engine is the intake flows the same amount as the ls6 intake... it would be a wast of your money to buy one... if your going to buy a new intake i would buy a fast intake......
Old Sep 7, 2008 | 09:53 PM
so keep the truck intake..... will an 80mm tb fit on it?
Old Sep 7, 2008 | 11:04 PM
ls1_chevelle's Avatar
Not sure on the TB but I'd slap some comp 918 valve springs on it. Spray it all day long with a 100-150 hit with a safe tune.
Old Sep 8, 2008 | 12:01 AM
2000lsxs10's Avatar
if you have the room under your hood to keep the truck intake i would keep it..... and im pretty sure the tb should fit on there,,, but you might want to double check i might be wrong.....
