Rubber grommet needed
Old Sep 13, 2008 | 10:21 PM
turbo kid's Avatar
Default Rubber grommet needed
Can anyone tell me what car comes with a round rubber grommet for the fire wall(where the injection harness goes through).I made a 1 1/8 inch hole in the fire wall for the harmess to go through (smallest I could get away with)and now need a grommt.Does a vette,f body or gTO use a round one?I will go and order one but for what kind of car?Thanks for any help.Dan
Old Sep 13, 2008 | 10:34 PM
jetlag's Avatar
Check Home Depot or Lowes, or similar type stores for your area... they carry different size grommets.
Old Sep 13, 2008 | 10:37 PM
turbo kid's Avatar
what department?Plumbing???
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
electrical supply house also if you cant find anything that large at above stores.
Old Sep 13, 2008 | 10:38 PM
red83's Avatar
nut and bolt drawers, plumbing, and electrical
Old Sep 14, 2008 | 05:23 AM
LS1MCSS's Avatar
This is a 1" ID, but I bet you could make it a little larger.
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 14, 2008 | 07:53 AM
Pop N Wood's Avatar
http://store.summitracing.com/egnsea...05&D=%2D146905
Old Sep 14, 2008 | 11:47 AM
V8Rumble's Avatar
Yep, that's what I chose also...
Old Sep 14, 2008 | 12:59 PM
stealth71's Avatar
The Seals It - 2 piece seals work great. I actually got one much smaller than I needed, didn't know it at the time, but I took my dremel with the sanding drum and they are easily enlarged.
