Another A-Body: 72 Malibu
Before
25k miles.
Iron 6.0
And the best part...
These heads have honkin' intake ports and valves.
That Gen IV, Iron block engine that came out of a 07+ HD or 3/4 ton truck with a few mod should be a good replacement for the old Gen II / LT1.
For on 25k, looks like the engine had a bit of a hard life. Should be able to clean up that carbon and rust without too much problems. What are your plans for the engine.. rebuild, mod it (H/C), etc ???
Are you planning on using the Variable Timing setup or have it mod' out?
For right now im just throwing in a 231/237 cam and springs and a full tune. VVT will be scrapped. With headers and an L76 intake, the goal is 400RWHP. Plans for next year is FI.
I really want this next year.
http://carshop.carshopinc.com/produc...457/C/S%202370
http://carshop.carshopinc.com/produc.../86959/C/S2349
http://carshop.carshopinc.com/produc...d/81168/LS1PAN
http://carshop.carshopinc.com/produc.../102204/LS-S10
http://www.performancetrucks.net/for...d.php?t=424440
Good news, it fits with the 87mm DBW throttle body. Now I dont need to swap the water pump or TB.
I will be taking my ECM to Larry at Speedinc this week to get a base file loaded for initial startup. After that I have to wait to sell my Prius to get the Autokraft pan and Eddy headers.
Until then, I will be detailing the block. Anyone care to guess what color paint will be used??
I am using the factory 1972 350 frame stands that have never been unbolted. The bellhousing is about 1/2" apart from the block. I will slide the trans forward to compensate but I feel Edelbrock has done their homework. I also received the Edelbrock swap headers. They look great.
The headers have a 3.5" to 3" reducer and I'm thinking of changing to a 3" exhaust. I'm not sure if 3" is too much for a street 6.0 revving to 6500. Any input would be appreciated.
With a mild cam and L76 intake, 400 RWHP is very easy.
I used Andrew's GTO as template for my clutch setup.
Indexing the factory 621 bell. It was out .0035, within spec of Tremec's .005 max.
I bled the clutch and I like the way it feels. Its firm like my last Ram 900 manual clutch but with about 1/2 the pedal travel. I should be able to bang gears with the quickness.
I test fit both headers and I am very impressed by them. I did have to remove the steering shaft the get the driver side in. Clearance is good all around except by the oil sending unit housing by the oil filter. I used the Z06 housing its very tight against the header. I should gain a tiny bit of clearance when I install the header gasket, but not much.
The fuel system has been completed using the Vette filter/regulator. As previous posts noted, I did have to grind the Russell adapter to fit them on the inlet/return side. For the outlet/feed I used a Napa tube cut off with a Swagelok stainless compression 3/8" to -6an adapter. I used the SS-600-6-6AN. It was $15.00 and very easy to install. Hopefully it doesnt leak. I have to give Harris Speedworks props again for the fast service making the teflon braided return hose. I might try building braided hoses one day, but I prefer to have a pro build them for me.
My harness should be in by early next week. The goal is to fire it by the end of December.
