clutch assembly
The problem is, after bleeding the system, the clutch doesn't disengage. I am wondering if I failed to buy and assemble some critical piece (pilot bearing? throwout bearing?). The clutch did not come with an alignment tool, which I thought was strange, but maybe that comes with one of these bearings that I didn't buy. Please don't tell me that I need to drop the engine and remover the trans to resolve my stupidity.
Using a mirror or tv scope.. ?.. and see if the throwout bearing is engaging the clutch arms ?
Yes, you should have or need a pilot bearing in the crank. Not all Clutch manufactors ship there clutches with alignment tools.. I just use an old input shaft or buy a Clutch Alignment tool.. they are pertty cheap anyways and you can always use it on almost all cars.
I would think that if you were able to slide the Trans in, all sould be ok!? see if you can check to make sure the Throwout bearing is really engaging the Clutch and is traveling enough to dis-engage the clutch !?
Keep us posted !
Second-Something else is wrong if your not dis-engaging the clutch. Im afraid you will have to tear it apart.
What else could be wrong to prevent the clutch from disengaging? We have bled it several times, and the pedal pressure is quite firm.
Sounds like my problem is the (lack of) pilot bearing? Would this be the cause of it not disengaging, or is there something else going on?
If it as a A4 car, there would not be a pilot bearing in the end of the crank by default. If it was a Crate engine, same think, doesn't ship with one install.
If it cam from a M6, it should have one unless someone took it out.
As noted above, the pilot bearing is a completely different issue. Since you have to pull the tranny, clutch & flywheel anyway, should definately have the pressure plate/ flywheel assembly balanced (if not done).
Did you use the shim behind the throwout bearing? It's not always needed, but, seems like it was in your case. I have no trouble w/ my spec 3+ to T-56 assembly. Different clutch pressure plates have different dimensions, as well. Did you use a stock bell housing? Sounds to me like there is a dimesnional issue w/ your set-up. When you take it out, pull the tranny back an 1/8" or so & look to see if there is a gap between your slave & pressure plate. If you used the spring on the slave/throwout assembly, there will not be a gap between the slave & the pressure plate.
Once removed, check the flywheel to pressure plate finger dimension, the retracted slave cylinder dimension, the slave cylinder shim & the flywheel thickness (where is mounts to the crank shaft, add them up. Then measure from the splined end (not including the small diameter that sticks out for the pilot bearing) to the slave cylinder mount on the front of the tranny. These dimensions should be close. Then measure from the slave cylinder mounting surface to the end of the bell housing. Use the numbers to determine if the splined shaft location ends up just ahead of the crank shaft when the bell housing is bolted up.
Anyway, sounds like a lot, but it isn't. What is meant is to look @ the assembly as you remove the tranny & you will find the dimensional problem. Swaps aren't always assembled the same as a stock application. So, maybe you did something to change the slave cylinder to pressure plate relationship.
Another thought - I wonder if adjusting the position of the threaded rod between the master cylinder and the clutch pedal might make a difference. If it was too far out or too far in, you would not get a full stroke. I will see if I can adjust this...
Yes, that is the adjustment on the adjustable master cylinder. Back the rod out of the pedal hole (toward the master) until you feel resistance, then the cylinder is pretty much adjusted.
BTW, I actually over extended the first HTOB. It is only once I ordered a replacement HTOB that I got an instruction sheet telling me how to measure for the clearance. I needed a half inch of shims. I had a Keisler unit, so not the same as yours.
