LS6 Heads Standard On 4.8 And 5.3 Engines?
Old 01-07-2009, 11:28 AM
NemeSS's Avatar
Originally Posted by 04ColoradoZQ8
The motor I bought for my LSX swap is the L33 out of an 05 Silvy, it has the 799 casting heads and Alum. block. So I can't wait to install this beast in my 04 Colorado. When I have the cam done I will have the heads sent out to be ported and polished, a small gain, but a worthy one.
so a aluminum blcok came out of a silverado? thats odd,
i didnt think aluminum blocks would be found on other than tbss and hi end 6.2 suvs with l92 motors.
u will see more gain with a better intake manifold and a slight mill of the heads for more scr than p&p. the 5.3 will amke use of the available airflow, it doesnt really ned anymore flow,
med. size cam, ls6 intake and hi flo exhaust will make some power.
Old 01-07-2009, 12:00 PM
philntx's Avatar
Nothing odd about this at all. It was on the option list.
Old 01-07-2009, 12:26 PM
NemeSS's Avatar
news to me
Old 01-07-2009, 02:18 PM
Bo185's Avatar
The 2004 LM4 and 2005 up LH6 5.3L in Trailblazers was aluminum as well. With AFM on the LH6
And the 07 GMT-900 truck also have an option all aluminum 5.3L. All the new ones are flat tops as well. (I believe)
Old 01-07-2009, 03:15 PM
jfg455's Avatar
05 up silverado with a 8th vin digit B has the HO 5.3 aluminum block motor in it.
Old 01-07-2009, 05:16 PM
Shawn MacAnanny's Avatar
My 2007 5.3L Impalla SS/Monte Carlo ss had 243s. Got the engine and trans for $500 from ebay. They are 2.0 intake and 1.55 exhaust valves.
Old 01-13-2009, 07:25 AM
seawalkersee's Avatar
Are the chambers the same size on the heads?
SWS
Old 04-26-2009, 09:29 PM
3stgstocker's Avatar
Default 799 combustion chamber
i got a set of 799s off a 08 truck 5.3 im putn on my ls1 for my toyota mudbog truck .is the combustion chamber smaller than the ls1 head if so how much i was goin to use them to get the compression up a little bit an better flow
Old 09-29-2009, 03:42 PM
sand man's Avatar
another domb quistion by me
are the new 2007+5.3 6 main bolt engines?
Old 09-29-2009, 03:49 PM
NemeSS's Avatar
every single ls engine is 6 bolts mains from day 1
Old 09-29-2009, 04:35 PM
Bacon505's Avatar
Yes, they are. Mine had (has) 799's on it and flat tops, I'm replacing them with a set of 317's to drop compression a bit for the turbo build....anybody need them?
I think the 799's have a 66cc chamber, I heard as much as 11:1cr when they'r swapped onto a 6.0!
Old 09-29-2009, 04:46 PM
  #32
fast's Avatar
lots of misuse of terms on this site
243 is a 243 ... not all 243 are LS6 heads ... whatever
now apparantly 243 is a 799 ... good ole gm
Old 09-29-2009, 04:55 PM
  #33
sand man's Avatar
great to know thanx
Quick Reply: LS6 Heads Standard On 4.8 And 5.3 Engines?
