Ls1 Temp Sensor Adapter
Old Jan 29, 2009 | 09:41 PM
LS2IROCZ's Avatar
check out street & performance they sell alot of stuff for ls1 swaps.
http://www.hotrodlane.cc/
Old Jul 30, 2009 | 07:05 PM
dragracing91lx's Avatar
anybody know what part number the electric sender is that works with part number 2277?? i had one on a camaro but i had to drill out the 2277 so the sender would slide through it
Old Sep 9, 2009 | 01:59 PM
Jake Harsha's Avatar
Lightbulb
I also found this thread helpful, but I was unable to find an adaptor for my sender application and I had to cut this particular Gordian Knot (so to speak)...
I had a set of VDO Cockpit series gauges/senders from my previous (old school/Ramjet 350) engine and the sender housing was much too large to fit an adaptor. I solved this by taking the sender to a machinist friend of mine and having him machine the threaded area of the sender to 12MMx1.5 on a lathe. He also made me a berylium copper washer. Here's some pics:
Before--shown with plug for comparison:
After--shown with plug for comparison (crappy cellphone pic):
Installed in the passenger side head (crappy cellphone pic):
Hope this helps someone else,
Jake
Old Sep 9, 2009 | 02:10 PM
TomM's Avatar
Autometer #2259 fits their adapter.....
T,
Old Sep 10, 2009 | 04:46 PM
Ravenous T\A's Avatar
T,
yea but 2259 is for the Autometer Gauges, might be a off maybe temp wise if used on another but im not sure?
Old Sep 11, 2009 | 04:39 PM
Blue92coupe's Avatar
Originally Posted by Pop N Wood
Another trick is to drill out and tap the block heater plug to fit the sensor. The plug is in the block just below the stock temp sensor.
is this the plug at the very front near the timing cover? If so is there a plug at the rear of the block you could do the same thing too?
Old Sep 12, 2009 | 09:59 AM
Pop N Wood's Avatar
That picture is for the block. The part on the far left is a block plug drilled out and tapped with a 1/2 NPT.
The block has a heater plug on either side. One under #3 cylinder and the other back by the starter
Old Sep 12, 2009 | 12:22 PM
Hmm I wonder if the 5.3 is different. Mine has a big plug on the drivers side under number 4 and a small one up front by the timing cover and a a small one on the passenger side the is facing up and down back by the starter. So is the big one under #4 the one im going to want to use???????
Old Dec 10, 2009 | 10:02 PM
deuce4935's Avatar
Originally Posted by Scooter70
The PCM needs to see the stock LS1 sensor, so you need to keep that one in the driver's side head. I drilled and tapped the passenger head and put an original sensor there. There's a company that makes new sensors that put out the same response as the originals but for some reason I can't think of the name right now.
Is this also true for the oil pressure sensor? Does the pcm need to see the sensor or can the sensor be ran directly to the gauge?
Old Dec 13, 2009 | 09:19 AM
flame's Avatar
No the PCM doesn't need to see oil pressure
Old Feb 6, 2015 | 12:31 PM
91foxbodygt's Avatar
Originally Posted by 6spdgto
I like your thinking! How did you re-tighten the brass plug into the blog since the allen head center is now gone? I was thinking maybe a hole on either side and a spanner wrench.
How would this work without the allen wrench center?
