Don't want power steering or a/c on my LS1 swap!
![](http://album.hybridz.org/data/500/medium/Alt_final_mount.jpg)
My motor has the corvette belt routing. I originally bought an F body alt mount and had it machined down by 3/4 inch to work with the vette belt spacing. But that put the alt right on my steering gear.
None of the top mount options worked with a stock alternator. A vette bracket would hit the strut tower. Mounts putting the alt where the tensioner didn't work since the vette belt runs closer to the block putting the alt into a head.
Ended up pulling a Denso alt off a celica, fit it with a 6 rib pulley off a supra then made my own bracket. Works like a champ. No belt slipping that I can tell. 85 amp alt is all I will ever need with this carb'd motor on a car with no electronics.
I ran this same setup, but the top bolt on the alternator is about 1/8" from hitting the belt. Not sure where I went wrong
The belt is also a really tight fit. Will prob look into getting a smaller diameter pulley to go on the alternator bracket (or maybe the "aftermarket pulley" is a smaller diameter?). The tensioner only has about 1/4" of play before it bottoms out to the right.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
