LM7 240SX Build
My goals for this car are really just to be a fun beater car, faster than it used to be and at least as reliable as it already was, without spending too much money on it. I don't care about maximum power, a V8 with double the displacement is gonna be awesome no matter what.
Trying to be cheap, so I've got most of my parts off Craigslist second-hand, rebuilt T56 with a scatter shield, mystery LM7. Motor doesn't have EGR, it's drive by cable, I think it's from an 02? I'd like to stick with OEM exhaust manifolds, but I don't think any fit. The long tube headers are all ridiculously expensive. The truck intake and alternator don't fit under the hood, but it's too expensive to switch, I guess I will just go hoodless for now, unless someone just upgraded from their LS1 intake manifold and wants to let it go cheap
Pics or it didn't happen:
Pic 1, all torn down
Pic 2, all buttoned up
Yeah all the info I've found on C5 manifolds is the same, it should work or may need some fabrication... Hooker lists the 8501HKR manifolds in the 240SX LS swap, they may work too... but I called them and they couldn't promise it. Guess it all comes down to how much I wanna spend.
Got some pictures of the C5 manifolds here in this post https://ls1tech.com/forums/conversio...l#post19061903
Stupid Photobucket killed all my links - just click on the broken picture icon and it'll open up in a new tab
http://i254.photobucket.com/albums/h...202_230319.jpg
http://i254.photobucket.com/albums/h...202_230308.jpg
I am running the Hooker swap kit and long tube headers but if I were doing it all again today I'd go with the block hugger cast manifolds.
If I remember tonight I'll try and measure how far away the steering column sits from the block/heads.
As far as the headers, Flat would have more experience since he did the swap in the S13.
Now that all the parts are here and reality has kicked in, I'm gonna be using the Sikky kit. I actually ordered the cheapo ISR kit, but it was backordered 8 weeks.
Get another 240! I've been driving 240's for years, started driving them before "Tokyo Drift" came out, when you could get one running with no major issues, unmolested, for $1000 or less. Lightweight, rear drive, great handling, reliable, and parts are cheap.
Rear main seal alignment tool from SacCityCorvette
Sikky mounts and oil pickup
Empty engine bay
hydraulic input line coming off slave cylinder
end of line coming from master cylinder
Do you have the bumper and crash bar off the car? There would be 0% chance to install the engine in my car without removing those.
The power steering lines are a huge pain in the *** - another reason why I went with the EPS.
