1981 Olds 98 turbo LS swap
Was going to use the stock hanger and install a pump. But the stock tank isn't baffled and I couldn't find one that was. So I decided to weld on a sump. Drilled some holes, modified the sump for the shape of the tank and welded her up. Used water to find any pin holes and welded them shut.
never mind i just reread its going to be turbo. I forgot about that while i read thru the thread.
