Convertible Vehicles Enthusiasts | Information | Maintenance
How to Repair a Torn Top
Old Nov 15, 2008 | 10:15 PM
DropTopBird's Avatar
Default How to Repair a Torn Top
I just noticed today (after a big rainstorm) that the carpet right under the window was soaked. When I looked at it from the inside, part of the top that was against the glass on the inside looks like it was torn and there is a little flap hanging down about the size of a dime. There is no visible hole from the outside, I think its just enough to let a constant drip in. Im almost positive its coming from there because the wet spot is centered right under that spot. Is there a special glue I can use to reattach that piece to the window and seal up the leak? Are there any products I can use on the outside to make sure the seal is still water tight? Thanks a lot.
