Convertible Vehicles Enthusiasts | Information | Maintenance
Convertible Window Alignment help
Old Feb 23, 2009 | 12:06 AM
6.0PSD's Avatar
Default Convertible Window Alignment help
So I replaced both my power window motors on my doors and the passanger side is great.
The driverside though seals horribly. There is tons of windnoise and it leaks in the rain. I tried adjusting the stops as far as up and down movement go, and got that as best I could. The problem I found out though is front to back.
If you are sitting in the car the window is to far towards the trunk instead of the hood. There is only about 1/8th the window inside the seal where the drivers side mirrors is when fully rolled up.
I have looked but not been able to find an adjustment for front to back, does aynone have any ideas, thanks!
