Convertible Vehicles Enthusiasts | Information | Maintenance
Top motor
Old May 16, 2010 | 08:44 AM
jhny777's Avatar
Default Top motor
When car was purchased top motor was just sitting in the trunk not bolted down.
Top will go down but not up.
Rebolted motor back in.Operated fine for a day.Then stopped.
Figured was ground so grounded the motor with a ground wire!
Still no workie.
so the question is where is the factory ground for the switch as the motor
has only two wires entering the motor!
Thanks for any help>
Old May 18, 2010 | 03:04 PM
GR8RYD's Avatar
No personal experience but I think it works this way. The motor has only two wires because the top up/down switch reverses the polarity of the 12 volts going to the motor and thus, reverses the direction the motor runs. I think I would be looking at your switch for the source of the problem. Good luck! Tom
Old May 20, 2010 | 11:24 AM
00Camary's Avatar
I have a extra pump motor if need be.
Old May 20, 2010 | 12:19 PM
JohnnyBs98WS6Rag's Avatar
If the motor works in one direction, it'll work in the other.
Sounds like your switch may be bad, not an uncommon occurance. The switch connects through the console harness, ground and power, I believe, come from under the dash. Like GR8RYD said, the switch reverses the polarity on the 2 motor wires. If the motor works in one direction, the ground and power connections to the switch are good and all the wiring is good. It's most likely bad switch contacts for the reverse direction.
Old Jun 13, 2010 | 08:52 PM
c-dub's Avatar
Hmm well my motor puts the top down, but when trying to go back up it goes "wrrrrm" and stops haha it just gives up...any suggestions?
Old Jun 14, 2010 | 05:18 AM
eseibel67's Avatar
If it trying, it's not the switch.
Probably a hydraulic problem. It takes more effort to raise the top than power it. Check the fluid first.
Old Jun 15, 2010 | 06:13 PM
c-dub's Avatar
ok fluid has been checked, looks a little low, how to fix? I looked up the sticky thread but it wasn't very informative other than."buy fluid, fill up" this is not the kind of thing I want to jack up? any helpfull tips?
Old Jun 17, 2010 | 08:25 AM
Top of the pump resevoir is a plug w/ a hex head. Remove that and fill w/ mineral oil up to between the double lines molded into the opaque resevoir. Replace plug, cycle the top up/down a few times to purge air. Recheck level and top off if required.
Old Jun 17, 2010 | 01:06 PM
c-dub's Avatar
mineral oil? haha where can I find that, or is that in afforementioned 5 gallon jug?
Old Jun 17, 2010 | 02:15 PM
Yeah, updated recommendation from GM. (Wierd, I know) You'll find it cheap in any Pharmacy (in the laxatives aisle).
Old Jun 17, 2010 | 04:17 PM
c-dub's Avatar
would you happen to have a link to that info? lol NO offense intended but that sounds kinda like bum scoop because it's so random.
Old Jun 18, 2010 | 10:41 AM
Another thread talks about this. Here's another thread that goes back a ways. I've had mineral oil in my system for over 8 years, no problems w/ it. So have many others.
Old Jun 18, 2010 | 12:55 PM
GR8RYD's Avatar
Thumbs up
Johnny speaks the truth..
Old Jun 20, 2010 | 02:54 PM
c-dub's Avatar
I appreciate the info, very helpfull
