Convertible Vehicles Enthusiasts | Information | Maintenance
Subframe connecters on vert
Old Jul 17, 2011 | 09:39 PM
js2fst's Avatar
Default Subframe connecters on vert
Any seen much difference? any gains? What kind of rwhp?
Old Jul 17, 2011 | 09:47 PM
94 Camaro Z28's Avatar
Subframe connecters won't net you any HP gains. Mostly just tightens up the car, especially in the turns
Old Jul 17, 2011 | 10:00 PM
BigRedZag's Avatar
Gave up waiting for 3pt ones after several years and installed bmr 2pts and it significantly changed the car for me. Much tighter, tracked better, etc.
Old Jul 17, 2011 | 10:12 PM
js2fst's Avatar
Flex looses hp though. I was wondering if any gains in 1/4 mile. And what kind of rwhp you had when you did it! I have had a set for 3 years to put on. I have heard it isn't huge difference.
Old Jul 20, 2011 | 07:46 AM
GR8RYD's Avatar
SFCs are the first thing I would do to any vert. They will extend the life of the car. Less flex means less things coming loose and falling off. I did not have them on my 91 Z28 and it shook itself to death. I put them on my 99 TA and it was still very tight when I sold it.
Old Jul 20, 2011 | 08:51 AM
js2fst's Avatar
I think there is a huge difference between a third and a fourth gen. Like I said I usually have a set on immediately. There has always been a excuse I would like three points but I have a set of bmr's weld on so I am thinking put them on. I hoping to go 550rwhp or more on a bigger stall too. So it might be more abussive than previous set up.
Old Jul 20, 2011 | 10:12 AM
farmington's Avatar
I'd plan on a 6 or 8 point rollbar also at that level of hp.
Old Jul 20, 2011 | 10:22 AM
Chevycrew's Avatar
I just installed a set of UMI weld in SFCs (but with the bolt in kit)(I wanted the option of welding later) on my 99 ss vert with 102k miles.
Made a huge difference in the feeling of the car. Tighter, more responsive, and less rattles, clunks, etc.
I still dont have any traction... (just a few bolt ons)
Old Jul 20, 2011 | 10:52 AM
99'CajunFirehawk157's Avatar
Have 2 point bolt in, car mostly stock hp, like the others posted, much better. Some vendor(s) is/are working on 3pt sfc's for verts, later this year or next, but they ARE in the works!
Old Jul 20, 2011 | 04:19 PM
js2fst's Avatar
I cut the chromoly 12 pt out. I am thinking of the 6-8 point. I want it to stay a street car. A true daily driver. Plans are to mini tub it too.
Old Jul 20, 2011 | 05:08 PM
7998's Avatar
I have owned 9 F-bodies and always shrugged off SFC's. I got to a point where I couldn't stand the handling anymore. I wish I would've done them a long time ago. Handling and ride is night and day.
Old Jul 21, 2011 | 07:35 PM
BobDoLe's Avatar
i'm sure if you drive like a responsible senior citizen, you might not notice much of a difference except for less rattles and squeaks over road surface irregularities.
Old Jul 22, 2011 | 01:16 AM
js2fst's Avatar
Driven hard daily. I was wondering how much to expect doing alot of different mods to car right now. Subframes are on to do list. We are trying to tweak all bugs out before the 408 goes in. We ditched the tci controller on 4l80e went to a speartech. Doing a front mount going to a 3.3 bar. Ditching the yank 3000 sc and going to the py 3600. And if that doesn't do it I will install the spare set ported 317's with patriot springs and put on a new set of 1.85 arms for extra lift. And also fixing Burkrafts screw up on the fab 9. (I should have done bought any other rear. these guys should be closed.).
Old Aug 8, 2011 | 01:20 PM
ragtopz28's Avatar
SFC a Must do IMO...
First time to track w/stickies...pop..sent crack all the way across windshield and RVmirror jumped off.
Replaced windshield(free in FL) and installed BMR weld-ins.
There are mixed opinions on STB but I got one..figured couldn't hurt.
Old Aug 8, 2011 | 07:14 PM
RONIN LSX's Avatar
What are the Pro's and Con's differences between Bolt In and Weld In? I would start off by assuming the Bolt In setup is an quicker, cheaper and easier install for someone that can't weld, but from there, what?
Old Aug 9, 2011 | 10:39 AM
farmington's Avatar
Like you said, bolt ins can be done in the garage with out a welder. All bolt ins can be welded in also if you feel the need.
